slightly OT - Eagle help please (problem almost solved)
Hi,
I freely admit that I am a newbie at Eagle - I taught myself to use it without printed docs while designing Morpheus. I gave up on the autorouter early, all my boards are manually routed.
The only way I know of moving the part outline from the top of the board to the bottom involves using the "Mirror" function, which can be invoked several ways, but I primarily use pressing the middle mouse button.
The problem: It flips the pins!!!!
I want to push the tPlace and maybe tName layers to bPlace and bName for resistors and caps, without it crossing the traces.
HELP!
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Post Edited (Bill Henning) : 7/11/2009 7:40:41 PM GMT
HELP!
Here's my totally biased opinion. I know there are many people here that like Eagle.
I fought with Eagle for a long time, even made a few two sided boards. It was always a pain, since Eagle is not intuitive.
I finally discovered DipTrace, which has a free version. It's totally intuitive, does everything I want and is very easy to use. Outputs standard Gerber files useable by any fab house.
Just my 2-cents worth.
Jim
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
I'll check it out.
Thanks.
Hmm... wait... mirror then rotate 180 degrees might work! I'll try that.
IT WORKED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
spoke too soon.
It decided to change the layers of some of the traces attached to the part. Argh!
Post Edited (Bill Henning) : 7/11/2009 7:41:32 PM GMT
It's not such a big wonder that the pins are "flipped". It's only a problem of your POV.
If the parts gets on the bottom-side, it *has* to be rotated. And chances are 50% that it rotates in the "wrong" way. So mirror and then rotate to your desires.
Re the autorouter:
Forget it. There's a doubt that any autorouter can make a good layout. You have to do that manually. Sometimes, the autorouter can help to find a single better trace. The key to success is a good placement and then a manual route.
I know professionals that use EAGLE and they would have to money to spend for something "better". But they stay wih EAGLE.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
With DipTrace, you just right-click on the part and say "change side." You're done.
Same for rotate, etc.
Jim
I wish it had single letter commands (like autotrax!) and a better highlighter, and being faster on OSX: it is incredibly slow (the newer 5.x versions are slightly faster than the 4.16 PPC on Intel hardware!)
Visit the home of pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Ya, the highlighter sucks for unconnected wires in some cases ... 99% routed huh??? [noparse]:)[/noparse]
--Steve
Again, totally agreed on auto routing. Works great for trivial circuits (a couple of transistors + passives) good luck on any complicated boards.
Then, when you select the silk layers for the bottom to use, choose the newly created layers. You can mirror the parts on the new layers if you want. The new layer has no more association with the part, it is just detached graphics.
If you haven't already noticed, if you are making the board into panels, each time you copy and paste the board into the panel, the names get incremented up with a number at the end which may be a headache. Don't use tNames on your silk in that case, always copy (ULP panelize) your final tName layer to the new layer, select the new layer for them to make silk from, and the names do not get incremented with numbers.
Post Edited (TChapman) : 7/12/2009 3:08:52 AM GMT
Chris Savage
Parallax Engineering
