Noise Problem Driving Relay — Parallax Forums
everesteverest Posts: 141
edited 2009-07-12 09:56 in BASIC Stamp
All,
I'm creating a PC controller relay board with my Stamp2 and I'm running into a strange "noise" problem. . .at least I think it must be noise. Here's the problem:
1) I've attached a photo that illustrates the circuit I'm using. If I create this circuit as shows on the breadboard, it works fine.
2) For "production" I have created a dedicated project box that leverages a Cat5 cable to run VIN, GND, and three pins to/from the Stamp2 module
PROBLEM: Wired as shown on the breadboard it works fine. When using the Cat5 to run out to my relay box, the relays "chatter" when the Stamp2 Pin connected to the base on the transistor is LOW. When I take the pins HIGH the relay closes just fine. . .but the "chatter" bothers me. . .relays shouldn't vibrate like that. I have no idea why this is happening. . .can anyone help me?
I've attached photos of the circuit on a development board. I'll follow up with a photo of the "production unit" that shows the Cat5 cable.
Here's some sample code that simply cycles pin0 high/low. As I've said, on the production unit the relay vibrates/hums when the pin is low. . .and I want that to stop. Any suggestions would be much appreciated. Thanks!
-Jeff
**** Super simple code *******
' {$STAMP BS2}
' {$PBASIC 2.5}
OUTPUT 0
Main:
PAUSE 1000
HIGH 0
PAUSE 500
LOW 0
PAUSE 500
GOTO Main
Post Edited (everest) : 7/5/2009 5:24:21 PM GMT
  • everesteverest Posts: 141
    edited 2009-07-05 17:20
    Here's a photo of the "production" relay unit. . .I suspect the problem MUST be with the Cat5 cable. . .but I'm at a loss to explain the relay chatter/hum/buzzing. . .
    -Jeff
    800 x 600 - 129K
  • stamptrolstamptrol Posts: 1,731
    edited 2009-07-05 20:49
    Jeff,
    Take a few minutes and generate a schematic for us. Particularly, what's in the box and where does the CAT5 go ?
    A couple of things right off is the (apparent ) lack of a diode across the relay coil to control the inductive voltage when the relay releases.
    Also, using CAT 5 is fine but you have to remember to use the twisted pairs as pairs to minimize the coupling of spikes from one conductor to another.
    The chatter/hum when the Stamp pin is low is troubling as the transistor is off at that point so if the hum is there, it means something is forcing that pin high against its will.
    Tom Sisk
    http://www.siskconsult.com
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-05 21:15
    radio shack 275-0249:
    DPDT 5A at 240VAC/24VDC
    Nominal coil rating of 12VDC, maximum 15.6VDC
    ** Pickup/dropout voltage 9.6/0.6VDC **
    Nominal coil current 60mA
    You may be operating the relay more like a buzzer?
    hth
    - H
  • Alan BradfordAlan Bradford Posts: 172
    edited 2009-07-05 23:59
    The Code looks simple enough.
    How long is the cat 5 cable your running?
    If it is too long it may be dropping too much voltage to activate the relay.
    But the Pause stastements would make it only try every 1/2 second.
    I think your problem may be a wiring mistake in the production unit.
    Are you using an AC to DC power supply?
    If the transistor turning on causes a short it may be resetting the Stamp...Except for the Pause statements again!
    I would first try to use the breadboard and the cat 5 cable to rule that out.
    Then I would look at the power supply closely (if it is an AC supply)
    What are the contacts of the relay switching?
    If that circuit is running from the same power supply, and shorting the PS then it would make the relay buzz.
    The voltage energizes the coil , closing the contacts, causing a short, causing the voltage to drop and denergizing the coil, removing the short, causing the voltage to go up,, energizing the coil........
    Voila....Instant Buzzer. Been there and have lots of the t-shirts!
    Try disconnecting the load from the realy contacts.
    Good luck,
    Alan Bradford
    Plasma Technologies
    www.plasmatechnologies.com
    Alan Bradford ·N1YMQ
    Plasma Technologies
    Canaan NH 03741
    edited 2009-07-06 00:00
    Good luck,
    Alan Bradford
    Plasma Technologies
    Plasma Technologies
    Canaan NH 03741
    edited 2009-07-06 03:45
    Hey guys,
    Thanks for the info. . .here's the weird part. I don't think this has anything to do with the Stamp2. The relays will "buzz" when I even *touch* the wires that connect to the Stamp2 pins. I can disconnect the Stamp2 pin, and if I hold the Cat5 wire in my fingers, the relays start buzzing!! They don't even have to be connected!?!?! For clarification, the relays CLOSE just fine. When I take the pins high, the relay snaps closed with no problems. It's when I take the Stamp2 pin low that it starts to buzz. Rather than just going into a state where the relay is open, it buzzes like it's trying to close! Note that the relays don't have loads connected at this point, there is nothing connected. I just can't figure this out for the life of me.
    I'm suspecting that it must be the Cat5 cable at this point. . .something is screwy. I'm going to try a straight phone line (no twisted pairs) and see what affect if any that has.
    -Jeff
    edited 2009-07-06 03:46
    Oh, and sorry about not posting schematics. I haven't the slightest idea how to make schematics other than PowerPoint and honesty it just takes forever. . .is there better software out there?? Hopefully that I don't have to spend a bunch of $$ on [noparse]:)[/noparse]
    -J
    edited 2009-07-06 03:52
    If you have to, draw your schematic by hand on a piece of paper with a fine tip marker, then scan the result in and attach that to your message.
    There's very little way to help you without a detailed description of what is wired to what and the best way to do that is with a drawing.
    edited 2009-07-06 05:03
    Someone doesn't get the idea that providing a schematic is a normal courtesy when asking for help. Communications really gets bogged down without it . In some cases, just drawing the schematic identifies the error.
    Ain't gadetry a wonderful thing?
    aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    edited 2009-07-06 05:05
    Okay, well I can do that!! Attached is a hand drawn schematic. . .sorry if it's not done correctly, I just did the best I could. The transistor is an NTE48 and I've tried several relays, all of which exhibit the same behavior. When I use a cord to run the GND, Vin, and Stamp Pin more than a foot or so, I get a "buzzer" when the stamp pin is LOW. It works fine when it's HIGH, but chatter when low.
    Even when I just wire this up straight on the development board, if I touch the resistor or diode and touch the metal. . .the relay immediately starts to buzz like crazy, again only if the Stamp2 pin is LOW. If it's high the relay snaps closed and the buzzing stops.
    Any suggestions though would be much appreciated. Thanks!
    -Jeff
    1598 x 1305 - 121K
    edited 2009-07-06 05:19
    Well, the diode on the base is unnecessary and creates a 0,7 voltage drop on the input. The transistor is NTE48 and if it is a Darlington transistor, the native 1.2volt voltage drop may be causing your chatter. The diode is suppose to be across the relay in the reverse of the normal power on direction.
    Another source of the chatter may be inductive electricity from something like flourescent lights as the Darlington is high gain. It may require a pull down resistor in order to remain fully off. You really should avoid a long wire from the BasicStamp to the Darlington base as this works as an antenna. If you need a cable, it should be from the +12 and the transistor's collector.
    Pls forgive the gripe, I am happy to help as I want to build something similar and am worried about mysterious chatter.
    Post Edited (Loopy Byteloose) : 7/6/2009 5:52:27 AM GMT
    edited 2009-07-06 05:32
    In the schematic, it looks like you are trying to drive a 12 volt relay with +5 volts. Is that true? The relay drops out at 9.6volts, maybe a bit more. 12volts minus the 1.2 Darlington pair voltage drop put the supply to the relay at 10.8 volts which is cutting it close. A 13.2 volt supply might do better.
  • EverQuriousEverQurious Posts: 48
    edited 2009-07-06 05:51
    I don't see an obvious problem other than the placement of the diode as stated above, but you may try a 10K pull down resistor from the input line to ground. I have used the same circuit many times ( I use a 2N2222 transistor ) with no problems. As for creating schematics there are plenty of free programs out there but I like to just use PAINT. I created a template page with all the components on it and simply cut and paste them as needed.
    I think Loopy Byteloose is correct in that you can't drive a 12v relay with a 5v supply.
    EverQurious
    Post Edited (EverQurious) : 7/6/2009 6:11:57 AM GMT
    edited 2009-07-06 06:00
    I've only recently added the diode, but have tried it every which way. . .I've tried changing up the resistor, the results are exactly the same with or without the diode. I tried a 10k resistor but not on the ground connection, I did place one between the collector and the coil, but that too had no effect. This is just super super confusing!
    -Jeff
    edited 2009-07-06 06:11
    The attached PDF is a typical relay driver, but not a Darlington transistor. Using a 2n2222 may resolve your problems as the gain is about 50 rather than 1000. Also, not shown is the idea of a pull down resistor in order to keep the Darlington off when +5 is missing. The pull down could be another 2.5K or larger resistor from the base of the Darlington to ground. This assumes you keep the 2.5K resister on the base to the BasicStamp.
    By using a Darlington, an on condition requires extemely low current - the region of micro amps. And so that is where the sensitivity to noise creeps in.
    edited 2009-07-06 06:19
    Everest,
    Sun Microsystems has sponsored a project called Open Office, which is an alternative to Microsoft Office. There two great aspects about Open Office: 1) it works, and 2) it's a free download. If you wish to add that it has compatibility with Microsoft Office, then there's three neat things about it.
    Included in Open Office is the Drawing application that may fill your needs. The other applications are:
    Text Document (Word)
    Presentation (Power Point)
    Database (Access)
    Spreadsheet (Xcel)
    Drawing (drawing tool, don't know if MS Office has a counterpart outside of Word)
    Formula (formula editor, don't know if MS Office has a counterpart)
    You can find this package at www.openoffice.org - it's between 200 - 300meg big.
    DJ
    Instead of:
    "Those who can, do.· Those who can't, teach." (Shaw)
    I prefer:
    "Those who know, do.· Those who understand, teach." (Aristotle)
  • SandgroperSandgroper Posts: 62
    edited 2009-07-06 12:11
    There are quite a few free electrical drawing packages out there.··Have a look at·Switcher Cad·at http://www.linear.com/designtools/software/ltspice.jsp·
  • alphamike27alphamike27 Posts: 10
    edited 2009-07-06 13:19
    The diode is the problem.
    When the stamp pin goes low it does not pull the base of the transistor to ground.
    The diode is not required, get rid of it.
    edited 2009-07-06 14:20
    I agree with Stamptrol - a diode across the relay is good insurance.··Cathode to 5v side, anode to ground side.· Check the manufacturer's data sheet·for·recommendations first though.·
    edited 2009-07-06 14:39
    I think I have already shown you the problem, which Loopy also noticed. The problem is independent of the diode, which also causes issues.
    - H
    edited 2009-07-06 14:59
    alphamike27 has a very good point that the diode on the input would cause the base to remain .6-.7 volts above ground. With the high gain of a Darlington, that could very well be causing the problem. If so, a pull down resistor may not be needed if it were removed.
    But you still have the 1.2 to 1.4v drop by using a Darlington transistor. A normal transistor has only a 0.6-0.7v drop. Trying to provide a 12v relay from a 12v supply with a Darlington pair is a bit dicey. So you may have to decide if you want a 13.2volt supply or forgot the high gain of the Darlington. If you really must have high gain, use a 2n7000 mosfet instead and you also won't have to deal with the voltage drop issue. A 12v power supply will be fine. The mosfet will likely work fine with the 2500 resistor to the gate.
    Eagle CAD will draw the schematics, has a good library of componets, and even route a small board for free. I have Open Office, but I rarely use the Draw feature as it is a hassle to draw transistors, resistors and capacitors. Parallax SPIN provides a font that will draw all these quite easily in text.
    Post Edited (Loopy Byteloose) : 7/6/2009 3:12:57 PM GMT
    edited 2009-07-06 16:38
    Hi everyone,
    Thanks for all the suggestions. I strongly suspect that the transistor is the issue here. . .removing the diode doesn't solve the issue. In fact, I disconnected from the Stamp entirely and noticed some strange behavior. . .after energizing the relay, the transistor I'm using will still allow current to flow even after disconnecting the base entirely! Obviously it closes when I disconnect the ground, and then after reconnecting the ground it will not open again, until I connect it back to stamp and take the Pin HIGH. At that point even disconnecting entirely from the Stamp won't stop that transistor from letting current flow!!
    I've seen some schematics posted with different kinds of transistors, I'm going to stop chasing my tail with this and just use some "proven" components. Thanks everyone!
    -Jeff
  • hmlittle59hmlittle59 Posts: 404
    edited 2009-07-06 16:49
    5 vdc...I spent 3 ON - & - OFF Days trying to figure out why 1 out of 3 out puts was turning a Darlington transistor on for no apparent reason. On my board layout 2 connections went to the left of the board and 1 went to the right. The one to the right had the trace on the backside from the BS2e and on the topside the 5vdc power line crossed over it. I'm glade I was using a small Audible speaker for testing each output on the bench. While just sitting idol on my bench the cross talk(5vdc) would turn on the Darlington and the speaker would sound. Lesson Learned...I HOPE!!!
    This was on my 4th Board...But it's the 1st SMT Board of the same project.
    So to all BEGINNERS!!! and me
    Watch your wiring layout of (((whats near what line(s) and what crosses what line(s))))....The boards had a host of other problems that I fixed, but that one was a da da!!! $83.00 (3 boards) wasted...New Boards came up first time...Ya Ho
    I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
    hmlittle59
    Post Edited (hmlittle59) : 7/6/2009 10:15:42 PM GMT
    edited 2009-07-07 08:30
    When working with high gain Darlingtons or high gain Mosfets, an input of a few microamps or microvolts can trigger an on condition. So the circuit may require a pull down resistor to stabilize the input from electricity in the environment. And the input leads should be kept short.
    In this case, you have a rather long wire acting as an antenna on the finished product - not good. It would be better to have the long wire on the 12volt output to rela
    When I try to research Darlington Transistor Relay drivers, I cannot locate any example schematics. It appears that most designers avoid them and either use a 2n3904, 2n2222, or if more current is required, they use a MOSfet.
    Increasing the power supply to 13.2volts should indicate if the added voltage drop of the Darlington pair is the problem. With the increase, the problem may disappear. If it doesn't disappear, it is likely the high gain on the input side.
    Post Edited (Loopy Byteloose) : 7/7/2009 8:36:34 AM GMT
  • ceruleanplainsceruleanplains Posts: 11
    edited 2009-07-07 11:40
    I've had similar problems in the past where my ground wasn't the same between my power supply and my microcontroller. I recommend having a common ground and that would probably help out.
    I wrote this tutorial on relays if you're interested:
    http://www.societyofrobots.com/member_tutorials/node/187
    Post Edited (ceruleanplains) : 7/7/2009 11:49:32 AM GMT
    edited 2009-07-07 19:31
    Relay chatter, long leads -- coupling 60Hz into the coil, need a 0.1uF bypass capacitor (one lead connected to relay coil at +V and the other lead to GND.)
    edited 2009-07-12 01:55
    All,
    My local Radio Shack didn't have any 2n2222's in stock, but they did have some MPS2222A, and at .79 I decided to give them a try. They work perfectly!! No noise, no flutter at all! Thanks again for all the suggestions. I guess I should just stick to proven parts!
    -Jeff
  • pwillardpwillard Posts: 321
    edited 2009-07-12 02:30
    Parts to always have handy: good NPN general purpose switching transistors (2N2222, 2N4400 etc), 1K, 4.7K and 10K resistors, 2N7000's, 1N914 or similar, 1N4004 rectifier diodes.
    A lot of the OLDER 2NXXXX JEDEC (Joint Electron Device Engineering Council) style names have also transformed into many transistors with the same numbers and specifications just different prefixes (for US style transistors)
    The high gain of a darlington has its place... but when you just need a "switch", the 2N2222 is great. Lets look at it this way. It was introduced in 1962... and they still make them.
    en.wikipedia.org/wiki/2N2222
    There's nothing like a new idea and a warm soldering iron.
  • dev/nulldev/null Posts: 381
    Here's a great schematic tool: www.tina.com/English/tina/student_version
    You can even export stuff to Spice, and run it in Mathematica or some other analyzer if you want.
    Don't worry. Be happy
