New USB O'scope not working!
I just got the parallax usb O'scope and it doesn't work.
I got the scope by it self downloaded the drivers and installed the software (both versions)
on version 4.0 Next to where it says Connected device there is a red square and below it it says hardware not found.
When I plug it in windows says new device recognized and ready to use.
Unfortunately who ever engineered it couldn't have added a 5 cent led to let you know whether or not it working or doing something.
Could someone help me out?
What is the max V I can look at?
I know is says 20V pp. Does that mean 10V positive and 10 negative. I will be looking at mostly DC curcuits so does that mean nothing over 10V DC?
Not to doubt you but money is short and right now this is the only scope I can afford. I don't want to damage it. I don't think it would matter any way most of the stuff I will be looking at is simple circuits that run off a 9V battery, such as the kits you can buy at the electronics store. I'm in the process of "re-learning".
Thanks Hover1.
If there is any question about operating parameters,·it would be best to contact Parallax support·direct with the question, that way you will·know for sure.
It's just an email away and they are VERY helpfully people.
·Jim
