Propeller Proto Board Data sheet error
Timothy D. Swieter
I am looking at V1.2 (5/23/2008) of the Propeller Proto Board, Proto Board USB and accessory Pack data sheet. On page 3 is the Propeller Proto Board USB Schematic. In the schematic, in the USB section, there is a line missing from the emitter of the npn transistor to the GND symbol
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
www.tdswieter.com
Only reason I saw this is because of the daily deal. I need to put together a few Protoboard Nanos (thanks Jeff (OBC)) and I just·enlarged and printed out a portion of the page.
I guess the PCB gods will do what they will with me when I take the boards to the bandsaw. Wish me luck.
Jim
www.tdswieter.com
Going to implement all the capacitor suggestions based on the overclocking posts to try a circumvent the PLL problem. I probably need to since I have 5 - 6.25MHz xtals on order.
(Love your 3" LCD's)
On topic..the Proto Board USB layout reflects what the Non-USB proto Board should be.
Jim
