Voltage regulator problem
Hi
Being a newbie at electronics, I am trying to regulate voltage to a relay, which demands 12V.
I have successfully built a voltage regulator which takes 14.4 and gives 12V out (schematic).
Problem is, when I connect a second voltage soure with common ground (BLUE WIRE) to the regulator, the regulator output drops to 2V!!!
Any suggestions on how to deal with this?
Don't worry. Be happy
Can you show us a bit more of the circuits connected to each of those power supplies? Its almost as if your getting the 7.2 onto the pin 1 of the lm317 regulator.
Cheers,
Tom Sisk
http://www.siskconsult.com
