Voltage regulator problem — Parallax Forums
dev/nulldev/null Posts: 381
edited 2009-07-10 21:11 in BASIC Stamp
Hi
Being a newbie at electronics, I am trying to regulate voltage to a relay, which demands 12V.
I have successfully built a voltage regulator which takes 14.4 and gives 12V out (schematic).
Problem is, when I connect a second voltage soure with common ground (BLUE WIRE) to the regulator, the regulator output drops to 2V!!!
Any suggestions on how to deal with this?
Don't worry. Be happy
  • stamptrolstamptrol Posts: 1,731
    edited 2009-07-10 19:55
    Not to doubt what you're seeing, but there has to be some other electrical connection also happening when you make that single connection to the 7.2 v battery pack.
    Can you show us a bit more of the circuits connected to each of those power supplies? Its almost as if your getting the 7.2 onto the pin 1 of the lm317 regulator.
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
  • dev/nulldev/null Posts: 381
    Here is the complete schematic. I am running the relays on 14V now, hope I dont damage them.
