P8X32A-D40 Shortage Expected by August 1st, 2009 — Parallax Forums
edited 2009-10-17 03:22 in Propeller 1
Hello Propeller customers,
We are projecting a shortage of P8X32A-D40 (the DIP) processors relatively soon, perhaps within days after I post this message. The shortage will occur as a result of two variables: (a) increased demand for DIP parts beyond our projections; and (b) underestimation of several lead times in our enterprise resource business planning software.
We don't have accurate replenishment dates at this stage, but our preliminary projections are to have more P8X32A-D40s in stock by October; from history I assure you the date will change +/- 30-60 days. We will update this thread as our suppliers confirm our orders with actual delivery times. As you may know, fabricating chips involves several steps. First, wafers are made at the foundry. Next, they're sent to a packaging company. Finally, they're tested.
We do not foresee shortages with the P8X32A-Q44 or P8X32A-M44. The replenishment of P8X32A-D40s will include more inventory of the other two packages, too.
I post this to the forums because there are several Propeller tool and board providers present, and we feel it is important to give them some priority and advance warning.
Because of this shortage there will be no free or discounted P8X32A-D40s. Occasionally we have traded chips for customer applications or other purposes. Some level of ration-based distribution will be left up to Jim Carey, our Sales Manager.
Sincerely,
Parallax Inc.
    edited 2009-07-09 19:20
    A Propeller Shortage!!!!!!! :-O
    This is awful!! Outr only hope is that it is because they are spending extra time on the Prop II.............
    Toys are microcontroled.
    Robots are microcontroled.
    I am microcontroled.
    If it's not Parallax then don't even bother. :-)
    Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
    Cheap·shipping unless specified!··········150 left!!··
  • PainlessPainless Posts: 69
    Ouch, maybe it's time to learn to solder surface mount Props? I have to admit, I like the DIP chips for the ease of changing out IC's in sockets if required.
    Is it possible to use the QFN package chips and mount them into some kind of socket (like a Pentium CPU) so they can be switched out without soldering?
    Russ.
    edited 2009-07-09 19:33
    I felt a great disturbance in the Force, as if millions of voices suddenly cried out in terror and were suddenly silenced. I fear something terrible has happened.
    @Painless
    You mean like this? www.warrantyvoid.us/tiki-index.php?page=Protoboard+Nano
    OBC
    New to the Propeller?
    edited 2009-07-09 19:40
    @OBC
    I'm talking about using the QFN propeller chips, the ones that have no legs, and instead of soldering them to the board dropping them into an IC socket of some kind for easy replacement. The latest Pentium chips are similar to this concept in that they have no legs and are simply placed into a holding socket on the PC motherboard, which is locked down with a retaining arm.
    It looks like something along these lines is offered, found this link whilst googling:
    www.locknest.com/newsite/products/qfn/index.htm
    Russ.
    Post Edited (Painless) : 7/9/2009 7:45:39 PM GMT
  • trodosstrodoss Posts: 577
    edited 2009-07-09 20:11
    @Painless
    You could also make/buy a PCB DIP "Adapter" board, and solder on the QFP version, at least in the intermediate term. Not easy, but better than having to redesign PCB's like the MultiBlade/SpinStudio/Morpheus.
    edited 2009-07-09 20:15
    I am getting a panel of propmod made up which convert qfn to dip though different pinout. I can ship in less then a week.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • TubularTubular Posts: 4,774
    edited 2009-07-09 21:32
    Ken,
    Would it be possible for Parallax to create a variant of the PropStick USB where only the essentials (prop/eeprom/crystal) are loaded?
    I don't believe the PCB would need modification; just the loading pattern
    I believe this would be the simplest solution for we end users, while using an existing Parallax design framework
    tubular
  • jazzedjazzed Posts: 11,803
    edited 2009-07-09 22:17
    I have a PCB design that takes a QFN and makes it DIP40 compatible ... except that I can't get the friggin' QFN soldered down :<
    Ken, is there an allocation limit ? Propeller rations [noparse]:)[/noparse] I see qty 942 still on the Parallax store.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    Post Edited (jazzed) : 7/9/2009 10:23:57 PM GMT
    edited 2009-07-09 22:30
    I have one also and can get soldered on for $5+prop
    edited 2009-07-09 22:46
    FuturLec has some simple solutions for using QFP chips in a replaceable format, check out the 44 pin TQFP Adapter, $1.20 each.
    This is still not exactly what I was hoping for, something similar to >this< would make things much simpler. I'm hoping to be producing my own automotive product based on the propeller in the very near future (still a work very much in progress) and like the idea of a whole unit not becoming scrap (in the customers eyes) just because one chip needs to be replaced.
    Russ.
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-07-09 22:55
    SMT really isn't such a miracle and can be done by hand as fast as through hole parts. And even replacing them is in fact faster (as long as you don't use sockets, but I wouldn't use them in such an application anyhow).
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
    edited 2009-07-09 22:58
    @Nick
    Why wouldn't you use sockets in an automotive application? Because of vibration or simply personal preference?
    Russ.
    edited 2009-07-09 23:01
    I am guessing the industrial propertys and the fact that you would most likely never have to swich out chips.
  • waltcwaltc Posts: 158
    edited 2009-07-09 23:51
    Painless,
    Vibration is the reason why you go with soldered components vs. sockets. Also from a repair POV with the right equipment its just as easy removing and replacing SMT IC's as socketed ones.
    edited 2009-07-10 02:39
    You're right, SMT's are also so much nicer in terms of space. If I wanted to try some SMT work what would I need other than a much finer soldering iron tip?
    edited 2009-07-10 03:06
    Thanks for the warning Ken. That is customer service.
    I can only hope this is because of much more awareness of the chip and hence more demand smile.gif
    I need to get my QFP to 1.3"x1.3" pcb and sram pcb out (RamBlade thread)
    · Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
    edited 2009-07-10 10:42
    Vibrations, condensation etc. If you use sockets, they will have to be high quality and they cost a lot. And maybe you think about coating the assembled PCB with some PU or so. Then the socket's advantage is lost, because you can't pull out the IC any longer. smile.gif
    I don't want to drive you into SMT, but sockets in a production product are quite a waste of time and money. In my eyes.
    Nick
    YADRO
    edited 2009-07-10 12:16
    Back in the 80's we did a study on faults on pcbs returned and found the vast majority were socket connections, often fixed just by reinserting the IC. We ditched the sockets and the faults dropped dramatically. This is besides the cost savings, but of course, without equipment you cannot swap/remove the IC.
  • CassLanCassLan Posts: 586
    edited 2009-07-10 16:45
    Cluso99 said...
    Seconded Ken, thanks for the heads up.
    Rick
    Prop Forum Search (Via Google)
    edited 2009-07-10 16:51
    Thirded [noparse]:)[/noparse]
    One of the many reasons I like dealing with Parallax is nice touches like this.
    CassLan said...
    Cluso99 said...
    Rick
    www.mikronauts.com - my site my 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    edited 2009-07-10 17:02
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-10 19:21
    And fifth - as in the five I just ordered [noparse];)[/noparse]
    edited 2009-07-10 21:10
    Ahh, you are too kind to us. There's no reason for thanking us for providing bad news ahead of time.
    Here's a bit more detail about your demand. This graph shows our P8X32A-D40 sales for the last year. Parallax must supply DIPs for prototyping and some low-volume production, yet they are not the kind of package alone on which we can base a chip business. Our sales volume of this package increased the last couple of months, as you can see. Our projections for DIPs were relatively flat, representing an average of our monthly usage. However, a few "big" months changes the picture quickly. If the dollars from P8X32A-D40 sales are relatively low, why didn't we just buy some more several months ago? Because there's a minimum order quantity (MOQ) for Propeller wafers. Basically, we'll need to spend 1000x (or something like that) the monthly sales value of P8X32A-D40s to replenish the inventory for this package type. The wafers can be made into any Propeller package, of course, so some of them will be QFNs and QFPs. From history, though, we'll be making more QFPs than QFNs.
    Parallax Inc.
    Post Edited (Ken Gracey (Parallax)) : 7/10/2009 9:17:00 PM GMT
    580 x 458 - 39K
    edited 2009-07-10 21:26
    @cluso99 & Nick
    Thanks for the insight on this, it makes a lot of sense. I have to admit that the idea of not drilling umpteen holes in a PCB is a very inviting one, with some practice I'm sure I could get used to surface mount parts, my eyes aren't what they used to be but that's nothing a magnifying glass can't cure smile.gif I blame all those early years of staring at fuzzy old green screen 3270 terminals.
    @Ken
    The appreciation is well deserved, I've become recently addicted to parallax products and have been through a chip failure replacement process and have to say that I found you guys to have excellent customer service accompanied by some very enthusiastic support.
    Russ.
    edited 2009-07-10 21:31
    Ken,
    what can we - your customers - do to be of assistance?
    How about Planned PropHood ? [noparse]:)[/noparse])
    We pre-order and pay into an escrow-like account, knowing we have to wait. When we hit the magic number, you order the batch. And we become happy prop parents ( - with no messy diapers to boot! )
    Since you've graciously shown an internal sales metric, my I ask what led to the spikes in Sept-Oct08, Feb-Mar09, May-June09?
    thanks
    - Howard
    edited 2009-07-11 01:18
    CounterRotatingProps said...
    cool.gif Sign me up!
    I am curious too about the spikes, what caused them. Is the low point in May because people were holding off until the Prop Expo in June? Or maybe schools were getting out and people were traveling.
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
    edited 2009-07-11 03:29
    Ken: Gee, you guys are great, even publishing the graph.
    If I may pass some comments on the demand graph...
    As you know there has been a great deal of activity this year with new designs and software, the prop has become of age, at least in the hobby community. The introduction of multi-prop pcbs has meant more usage.
    The dip in May may be due to the price drop notification where stockists were clearing "old" inventory (cannot recall the exact date).
    The pricing on the prop has now meant that using it as an "intelligent" peripheral to other chips is cost effective. e.g. PropTerm is being used by the N8VEM (Z80) guys as a terminal.
    With more pcbs being released and operating type software coming, I can only see demand going higher yeah.gif
    edited 2009-07-11 03:36
    I totally agree.
    Personally, I've ordered around 140 DIP40 props in the last two months, just so I will have decent assured stock for my kits and upcoming assembled offerings.
    Cluso99 said...
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA
    edited 2009-07-11 04:41
    anyone know where one can get 44pin qfn pcb's that turn it into a 44pin dip?? i saw on one post they had a 32qfn to dip, but no 44qfn to dip?
    TERMS OF USE: MIT License
    "Permission is hereby granted, free of charge, to any pers...........................
    ..............................OMITTED FOR FORUM...............................................
    .................. OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. "
    The dsp/fpga king is dead, long live the prop.
    edited 2009-07-11 06:33
    I have a layout and if enough interest I can get a run made.
