Quick and Dirty Javelin Stamp Test Setup??
WBA Consulting
I have two Javelin Stamp boards that required rework to repair defects and I am under the impression that they should now be functional. I do not know anything about the Javelin stamps, but was wondering if there is a simple way to test them like the Basic Stamp tester http://forums.parallax.com/showthread.php?p=759839.
thanks in advance,
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
thanks in advance,
Andrew Williams
WBA Consulting
Do you want to test the Javelin module or the board?
regards peter
You could use the board posted at that forum link to test the Javelin Modules…first you would need code designed for it. We may have the code, but I need to do some digging. So if you’re willing to build the test board let me know and I will see what I can come up with on my end. Take care.
Chris Savage
Parallax Engineering
Andrew Williams
WBA Consulting
Chris Savage
Andrew Williams
WBA Consulting
Chris Savage
I'll post back when I can check it out.
Andrew Williams
WBA Consulting
