Quick and Dirty Javelin Stamp Test Setup?? — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,938
edited 2009-07-09 23:34 in General Discussion
I have two Javelin Stamp boards that required rework to repair defects and I am under the impression that they should now be functional. I do not know anything about the Javelin stamps, but was wondering if there is a simple way to test them like the Basic Stamp tester http://forums.parallax.com/showthread.php?p=759839.
thanks in advance,
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-07-08 21:27
    Would that be the Javelin Stamp Demoboard?
    Do you want to test the Javelin module or the board?
    regards peter
    edited 2009-07-08 22:33
    Andrew,
    You could use the board posted at that forum link to test the Javelin Modules…first you would need code designed for it. We may have the code, but I need to do some digging. So if you’re willing to build the test board let me know and I will see what I can come up with on my end. Take care.
    Parallax Engineering
    edited 2009-07-08 23:29
    Yes, I am willing to build the test board and have one half done already on perfboard, just got the SIP sockets today. I am actually doing a re-layout of it so that it completely fits within the form factor of the Zif socket using SMT parts.
    Andrew Williams
    WBA Consulting
    edited 2009-07-09 01:27
    Ok, I will see if I can get the code uploaded tomorrow for you.
    edited 2009-07-09 16:23
    No rush, I have to travel to "no-where", Oregon over the weekend, so I will be off the grid and without a computer.
    Andrew Williams
    WBA Consulting
    edited 2009-07-09 17:36
    Well good news anyway…I gave the test code to our Tech Support Josh Donelson yesterday and he was able to confirm that it works as I remember on the same circuits used for the BASIC Stamps. So I will attach the code here as well as add it to the Completed Projects project for the tester. As a note, both files in the ZIP should be in the same location.· You will load and run Javelin_Test.java and the J_test.class file should remain with it.· I hope this helps. Take care.
    Thanks, I'll give it a try when I can next week. Maybe I'll plug my iron into my inverter in the car and finish soldering my tester board in the car.... Maybe not......
    I'll post back when I can check it out.
    Andrew Williams
    WBA Consulting
