SXKEY VS Resonator
Frankly I am baffled, when I run the following piece of code on an SXTECH board with the sxkey, it works perfectly.· The scope shows the pwm width changing at the appropriate times.· When I program the chip with the same key remove the key and install a 20_000_000 resonator it will generate a pulse, narrower than normal and rarely get past one loop of the speed increase.
'·· File......AMotorrun.SXB
'·· Purpose...TEST PWM under local osc.
'·· Author.... Jim Meek
'·· E-mail....
'·· Started... June 30, 2009
'·· Updated...
' Program Description
' Conditional Compilation Symbols
'none
' Device Settings
ID············· "MOTTEST"
DEVICE········· SX28, OSCXT2, BOR42
'{$IFDEF HIGHSPEED}
FREQ 50_000_000
'{$ELSE}
FREQ··········· 20_000_000
'{$ENDIF}
STACK·········· 16
' I/O Pins
acclx··PIN·RB.7· INPUT PULLUP
TAC··PIN·RB.4· INPUT pullup
LED1··PIN·RB.0· OUTPUT
LED2··PIN·RC.4· OUTPUT NOPULLUP
M1Ctrl··PIN·Rc.0 OUTPUT NOPULLUP
M1Dir··PIN·Rc.1· OUTPUT NOPULLUP
trigger ·PIN·RA.3· OUTPUT NOPULLUP
TX··PIN·RA.0 OUTPUT NOPULLUP
' Constants
Tdone_mask·CON·%00000010
Adonex_mask·CON·%00010000
TBad_mask·CON·%00000100
ABad_mask·CON·%00100000
PB01··CON·%11111101··'low to hi
PB10··CON·%00000010··'hi to low
PB31··CON·%11111111
PB30··CON·%11110111
PB3Msk··CON·%00001000
isOn··CON·1
isOff··CON·0
Yes··CON·· ·1
NO··CON·0
CompEn··CON·0
cmp··CON·$08··'comparator enable mode
WkedB··CON·$0A··'Edge detect
WKpndb··CON·$09··'wake pending
'{$IFFREQ =50_000_000}
motorFreq·Con·230··'establishes base motor frequency
'{$ELSE}
motorFreq·Con·55··'establishes base motor frequency
'{$ENDIF}
pwid··Con·50
' Variables
Flags··VAR·Byte
Indx··VAR·Byte
tmpW1··VAR·Word
tmpW2··VAR·Word
tmpW3··VAR·Word
AccResult·VAR·Word
PWMWID··VAR·Word
TacResult·VAR·Word
AccDelta·VAR·Word
TacDelta·VAR·Word
'indxa··VAR·Byte
tmpB1·VAR·Byte @tmpW1_lsb
tmpB2·VAR·Byte @tmpW1_msb
tmpB3·VAR·Byte @tmpW2_lsb
tmpB4·VAR·Byte @tmpW2_msb
tmpB5·· VAR·Byte @tmpW3_lsb
tmpB6·· VAR·Byte @tmpW3_msb
'flags1·Var·Byte
TState·VAR·Flags.0
TDone·VAR·Flags.1
TSkip·VAR·Flags.2
AStatex·VAR·Flags.4
ADonex·VAR·Flags.5
Tinhib·VAR·Flags.3
AccRun·VAR·Flags.6
Sign·Var·Flags.7
MtrArray VAR·Byte(8)
m1ACC·VAR·Byte· @ MtrArray(0)·'accumulator for pwm
m1portb·VAR·Byte @ MtrArray(1)·'byte to send to port to run motor
PwmPin·Var·m1portb.0··'how we turn pwm on/off
Motoron·VAR·m1portb.1··'motor is running or not
m1Speed·VAR·Byte @ MtrArray(2)·'motor speed
M1Phase·VAR·Byte @MtrArray(3)·'pwm phase for motor isr
M1Delay·VAR·Byte @MtrArray(4)·'motor delay for pwm frequency
Speed·VAR·Word @MtrArray (5)·'motor speed
'{$IFFREQ <50_000_000}
INTERRUPT NOPRESERVE 100_000
'{$ELSE}
INTERRUPT NOPRESERVE 230_400
'{$ENDIF}
ISR_Start:
ASM
·Bank·· mtrArray···'the motorctl stuff is here
·sb·motoron···'The motor has not been enabled
·clrb·m1ctrl···'turn the motor off
·jnb·motoron,motor_done·'if off exit
·mov·W,#motorfreq
'·djnz·m1Delay,motor_done
·dec·m1Delay
·SZ
·jmp·motor_done
·mov·m1Delay,w
· ·setb· Trigger················ ·'Set oscilloscope trigger
······· setb· PwmPin················· ·'Set PWM bit in advance
· ·csb·· M1Acc,M1Speed········· ·' If PWM value reached,
··· ·clrb· PwmPin··············· ·' clear PWM bit
· ·inc·· m1Acc················· ·' Increment current value
······· mov·· w, #100·············· ·'Test if PwmAcc = 100
·mov·· w,m1acc -W
······· snz·························· ·'if so,
······· clr m1Acc················· ·'clear PwmAcc
······· mov·· rc, m1portb············· ·'Output port data
······· clrb· Trigger················ ·'Clear oscilloscope trigger
BANK 0
endasm
motor_done:
ISR_Exit:
·BANK 0
· RETURNINT ' {cycles}································
' Subroutine / Function / Task Declarations
DELAY_MS·SUB 1, 2
· PROGRAM Start
Start:
· PLP_A = %0000_0000
· PLP_B = %0001_0001
·PLP_C = %0000_0000
BANK @ MTRARRAY
\SETB motorOn
BANK __DEFAULT
Main:
m1Speed = 10
BANK @MTRARRAY
do while m1Speed < 100
·BANK @MTRARRAY
·m1Speed = m1speed + 5
'·BANK __default
·Delay_MS 2000
Loop
put @m1speed,0
DELAY_MS 500
goto main
' DELAY_MS encapsulates pause into a subroutine
' enter with pause duration in __wparam12
SUB DELAY_MS
· msDuration·VAR·__WPARAM12
· \ SB·· __PARAMCNT.1····' skip if word
· \ CLR· msDuration_MSB····'· else clear for byte
· PAUSE msDuration
ENDSUB
' User Data
I use CTL D if I want to Debug and I use CTLP when I want to program.· I remove the power and the SXKEY after programing and insert the 20 Meg resonator.· I have to admit, I have been running all of my stuff so far under SXKEY in DEBUG mode this is my first shot at running standalone.
'·· E-mail....
'·· Updated...
'none
' Device Settings
'{$IFDEF HIGHSPEED}
FREQ 50_000_000
'{$ELSE}
'{$ENDIF}
STACK·········· 16
' I/O Pins
' Constants
PB31··CON·%11111111
PB30··CON·%11110111
isOn··CON·1
isOff··CON·0
Yes··CON·· ·1
NO··CON·0
CompEn··CON·0
'{$ELSE}
'{$ENDIF}
pwid··Con·50
' Variables
Flags··VAR·Byte
Indx··VAR·Byte
tmpW1··VAR·Word
tmpW2··VAR·Word
tmpW3··VAR·Word
AccResult·VAR·Word
PWMWID··VAR·Word
TacResult·VAR·Word
AccDelta·VAR·Word
TacDelta·VAR·Word
'indxa··VAR·Byte
'flags1·Var·Byte
TState·VAR·Flags.0
TDone·VAR·Flags.1
TSkip·VAR·Flags.2
AStatex·VAR·Flags.4
ADonex·VAR·Flags.5
Tinhib·VAR·Flags.3
AccRun·VAR·Flags.6
Sign·Var·Flags.7
'{$ELSE}
'{$ENDIF}
ISR_Start:
ASM
·mov·W,#motorfreq
·dec·m1Delay
·SZ
·jmp·motor_done
·mov·m1Delay,w
·mov·· w,m1acc -W
BANK 0
endasm
motor_done:
ISR_Exit:
·BANK 0
DELAY_MS·SUB 1, 2
· PROGRAM Start
Start:
·PLP_C = %0000_0000
BANK @ MTRARRAY
\SETB motorOn
BANK __DEFAULT
Main:
m1Speed = 10
BANK @MTRARRAY
·BANK @MTRARRAY
'·BANK __default
·Delay_MS 2000
Loop
put @m1speed,0
DELAY_MS 500
goto main
SUB DELAY_MS
· PAUSE msDuration
ENDSUB
' User Data
regards peter
I tried changing oscxt to oschs2 with similar results.
Try OSCHS1. It has to be a resonator problem if it works with the Key providing the clock.
Bean.
The needy are many, the deserving are few.
RS_JIM
