SXKEY VS Resonator — Parallax Forums
SXKEY VS Resonator
RS_JimRS_Jim Posts: 1,775
edited 2009-07-09 03:54 in General Discussion
Frankly I am baffled, when I run the following piece of code on an SXTECH board with the sxkey, it works perfectly.· The scope shows the pwm width changing at the appropriate times.· When I program the chip with the same key remove the key and install a 20_000_000 resonator it will generate a pulse, narrower than normal and rarely get past one loop of the speed increase.
'·· File......AMotorrun.SXB
'·· Purpose...TEST PWM under local osc.
'·· Author.... Jim Meek
'·· E-mail....
'·· Started... June 30, 2009
'·· Updated...
' Program Description
' Conditional Compilation Symbols
'none
' Device Settings
ID············· "MOTTEST"
DEVICE········· SX28, OSCXT2, BOR42
'{$IFDEF HIGHSPEED}
FREQ 50_000_000
'{$ELSE}
FREQ··········· 20_000_000
'{$ENDIF}
STACK·········· 16
' I/O Pins
acclx··PIN·RB.7· INPUT PULLUP
TAC··PIN·RB.4· INPUT pullup
LED1··PIN·RB.0· OUTPUT
LED2··PIN·RC.4· OUTPUT NOPULLUP
M1Ctrl··PIN·Rc.0 OUTPUT NOPULLUP
M1Dir··PIN·Rc.1· OUTPUT NOPULLUP
trigger ·PIN·RA.3· OUTPUT NOPULLUP
TX··PIN·RA.0 OUTPUT NOPULLUP
' Constants
Tdone_mask·CON·%00000010
Adonex_mask·CON·%00010000
TBad_mask·CON·%00000100
ABad_mask·CON·%00100000
PB01··CON·%11111101··'low to hi
PB10··CON·%00000010··'hi to low
PB31··CON·%11111111
PB30··CON·%11110111
PB3Msk··CON·%00001000
isOn··CON·1
isOff··CON·0
Yes··CON·· ·1
NO··CON·0
CompEn··CON·0
cmp··CON·$08··'comparator enable mode
WkedB··CON·$0A··'Edge detect
WKpndb··CON·$09··'wake pending
'{$IFFREQ =50_000_000}
motorFreq·Con·230··'establishes base motor frequency
'{$ELSE}
motorFreq·Con·55··'establishes base motor frequency
'{$ENDIF}
pwid··Con·50
' Variables
Flags··VAR·Byte
Indx··VAR·Byte
tmpW1··VAR·Word
tmpW2··VAR·Word
tmpW3··VAR·Word
AccResult·VAR·Word
PWMWID··VAR·Word
TacResult·VAR·Word
AccDelta·VAR·Word
TacDelta·VAR·Word
'indxa··VAR·Byte
tmpB1·VAR·Byte @tmpW1_lsb
tmpB2·VAR·Byte @tmpW1_msb
tmpB3·VAR·Byte @tmpW2_lsb
tmpB4·VAR·Byte @tmpW2_msb
tmpB5·· VAR·Byte @tmpW3_lsb
tmpB6·· VAR·Byte @tmpW3_msb
'flags1·Var·Byte
TState·VAR·Flags.0
TDone·VAR·Flags.1
TSkip·VAR·Flags.2
AStatex·VAR·Flags.4
ADonex·VAR·Flags.5
Tinhib·VAR·Flags.3
AccRun·VAR·Flags.6
Sign·Var·Flags.7
MtrArray VAR·Byte(8)
m1ACC·VAR·Byte· @ MtrArray(0)·'accumulator for pwm
m1portb·VAR·Byte @ MtrArray(1)·'byte to send to port to run motor
PwmPin·Var·m1portb.0··'how we turn pwm on/off
Motoron·VAR·m1portb.1··'motor is running or not
m1Speed·VAR·Byte @ MtrArray(2)·'motor speed
M1Phase·VAR·Byte @MtrArray(3)·'pwm phase for motor isr
M1Delay·VAR·Byte @MtrArray(4)·'motor delay for pwm frequency
Speed·VAR·Word @MtrArray (5)·'motor speed
'{$IFFREQ <50_000_000}
INTERRUPT NOPRESERVE 100_000
'{$ELSE}
INTERRUPT NOPRESERVE 230_400
'{$ENDIF}
ISR_Start:
ASM
·Bank·· mtrArray···'the motorctl stuff is here
·sb·motoron···'The motor has not been enabled
·clrb·m1ctrl···'turn the motor off
·jnb·motoron,motor_done·'if off exit
·mov·W,#motorfreq
'·djnz·m1Delay,motor_done
·dec·m1Delay
·SZ
·jmp·motor_done
·mov·m1Delay,w
· ·setb· Trigger················ ·'Set oscilloscope trigger
······· setb· PwmPin················· ·'Set PWM bit in advance
· ·csb·· M1Acc,M1Speed········· ·' If PWM value reached,
··· ·clrb· PwmPin··············· ·' clear PWM bit
· ·inc·· m1Acc················· ·' Increment current value
······· mov·· w, #100·············· ·'Test if PwmAcc = 100
·mov·· w,m1acc -W
······· snz·························· ·'if so,
······· clr m1Acc················· ·'clear PwmAcc
······· mov·· rc, m1portb············· ·'Output port data
······· clrb· Trigger················ ·'Clear oscilloscope trigger
BANK 0
endasm
motor_done:
ISR_Exit:
·BANK 0
· RETURNINT ' {cycles}································
' Subroutine / Function / Task Declarations
DELAY_MS·SUB 1, 2
· PROGRAM Start
Start:
· PLP_A = %0000_0000
· PLP_B = %0001_0001
·PLP_C = %0000_0000
BANK @ MTRARRAY
\SETB motorOn
BANK __DEFAULT
Main:
m1Speed = 10
BANK @MTRARRAY
do while m1Speed < 100
·BANK @MTRARRAY
·m1Speed = m1speed + 5
'·BANK __default
·Delay_MS 2000
Loop
put @m1speed,0
DELAY_MS 500
goto main
' DELAY_MS encapsulates pause into a subroutine
' enter with pause duration in __wparam12
SUB DELAY_MS
· msDuration·VAR·__WPARAM12
· \ SB·· __PARAMCNT.1····' skip if word
· \ CLR· msDuration_MSB····'· else clear for byte
· PAUSE msDuration
ENDSUB
' User Data
I use CTL D if I want to Debug and I use CTLP when I want to program.· I remove the power and the SXKEY after programing and insert the 20 Meg resonator.· I have to admit, I have been running all of my stuff so far under SXKEY in DEBUG mode this is my first shot at running standalone.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-07-06 15:28
    I always use OSCHS2 on device line for resonators, never OSCXT
    regards peter
  • RS_JimRS_Jim Posts: 1,775
    edited 2009-07-06 15:42
    Thanks Peter for quick reply,
    I tried changing oscxt to oschs2 with similar results.
  • BeanBean Posts: 8,129
    edited 2009-07-06 17:31
    Jim,
    Try OSCHS1. It has to be a resonator problem if it works with the Key providing the clock.
    Bean.
    The needy are many, the deserving are few.
    Thanks All for the input. The problem seems to lie in the SX-TECH board. I tried the different osc combinations to no avail, next I replaced the SX-28 thinking that the problem was a blown chip. Finally, I built the motor drive circuit on an SX-28 proto board and it is setting there just happily running my motor circuit through its paces. Now, I wonder whats gon wrong with the Tech Board?
    RS_JIM
