viewing eeprom contents(viewport, DongleBasic, what can do it?)
No TV, no keyboard, no mouse how can i see the contents of the top half of a 64k eeprom?
DongleBasic was sugested but every time I enter in
i just get syntex error. any other ideas? downloaded viewport but that does not look like it can do it either.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Post Edited (mctrivia) : 6/30/2009 5:18:20 AM GMT
dump 32768 32768
dump [noparse][[/noparse] <EEPROM address> ] , <length>
In your case, it would be
dump [noparse][[/noparse] 32768 ],1
This is for the case of the boot EEPROM(s) on I/O pins 28/29.
> list
syntax?
RTFM?? well the manual gave a list of commands and some example programs, but that was about it ... gag me [noparse]:)[/noparse] Eventually I derived enough from pouring through the manual for it all to make sense (much like using a decoder ring [noparse]:)[/noparse]. After that I had to keep entering my programs by hand over and over again until finally begging a cassette out of my parents. Twas the night before Christmas and all through the house ....
So, you need to dump the contents of EEPROM. Ok, do you know how to make the driver access the EEPROM?
If so, you can dump to the serial port with FullDuplexSerial, etc....
If you like, tomorrow I'll whip up something for you that will work on the propmod I bought. I've been a little tied up [noparse]:)[/noparse]
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Post Edited (mctrivia) : 6/30/2009 6:01:37 AM GMT
EEPROM[noparse][[/noparse] <address> ] = <value>
This writes a byte value to the EEPROM
This reads a byte value from the EEPROM and returns the value
(which can be used anywhere an expression can be used).
[noparse][[/noparse] <address> ] can also be [noparse][[/noparse] <SCL pin#>,<address> ]
if you want to attach an EEPROM to any even/odd pair of I/O pins
did the trick. The first 5 bytes match the image i am trying to copy exactly
00 B4 C4 04 6F
but the image file on the SD has ED next and the EEPROM has FD
copy "FOOBAH.BIN",[noparse][[/noparse]$8000]
then compare with what you're copying with your program.
DongleBasic also allows you to sequentially read bytes from an SD file. Look at the OPEN statement
and the FILE "pseudo-variable". It's really quite handy for debugging this sort of thing.
the funny thing is I have used almost the same code to copy info off an sd card.
I am probably just missing something small.
@mctrivia, The ED and FD you mentioned are the checksum bytes which have about a %0.2 chance of being the same for two different programs.
--Steve
--Steve
--Steve
