Can XINPUT mode be used with the·crystal on the proto board?· I can't get·XINPUT or XTAL1 to work, only RCFAST n RCSLOW.· I can see a signal on X1 and X0 on my protoboard.· Is there any chance this is a repairable problem?
It's not a repairable problem unless you can replace the Propeller chip. Some people have done that, but I wouldn't suggest learning SMD rework by starting with a large package like the Propeller.
As far as I know, XINPUT requires an external oscillator connected to XIN. They come in pretty small packages these days and should be easy to wire piggyback on the Protoboard
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
The only thing that's broken is the PLL. You can use RCSLOW, RCFAST, or XINPUT modes.
agfa
chipquik.com
I often use it to remove fine-pitch devices. One of the free sample kits should give you enough to remove two or three Propeller chips.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 6/29/2009 7:16:19 AM GMT
I think I will take a stab at it.
agfa
http://chipquik.com/free.html
for the goods
BH
Leon
