PLL failure — Parallax Forums
PLL failure
agfaagfa Posts: 295
edited 2009-06-29 07:14 in Propeller 1
Can I run with the external crystal if the "dreaded PLL failure" occurs?
agfa
    edited 2009-06-28 15:57
    Yes
    The only thing that's broken is the PLL. You can use RCSLOW, RCFAST, or XINPUT modes.
  • agfaagfa Posts: 295
    edited 2009-06-28 16:24
    Thanks Mike.
    Can XINPUT mode be used with the·crystal on the proto board?· I can't get·XINPUT or XTAL1 to work, only RCFAST n RCSLOW.· I can see a signal on X1 and X0 on my protoboard.· Is there any chance this is a repairable problem?
    agfa
    edited 2009-06-28 17:09
    It's not a repairable problem unless you can replace the Propeller chip. Some people have done that, but I wouldn't suggest learning SMD rework by starting with a large package like the Propeller.
    As far as I know, XINPUT requires an external oscillator connected to XIN. They come in pretty small packages these days and should be easy to wire piggyback on the Protoboard
    edited 2009-06-28 17:15
    Thanks again Mike.
  • LeonLeon Posts: 7,620
    edited 2009-06-28 17:33
    Chip Quik makes chip removal very easy:
    chipquik.com
    I often use it to remove fine-pitch devices. One of the free sample kits should give you enough to remove two or three Propeller chips.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 6/29/2009 7:16:19 AM GMT
    edited 2009-06-28 17:47
    Thanks Leon,
    I think I will take a stab at it.
    agfa
  • BADHABITBADHABIT Posts: 138
    edited 2009-06-29 02:05
    Goto
    http://chipquik.com/free.html
    for the goods
    edited 2009-06-29 03:13
    how does it work?
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    It's Wood's metal.
    Leon
