Voltage Regulator mounting Prefrences
What is the best/preferred way to mount the lm2937 and lm2940 voltage regulators? Is it better to mount it flat or freestanding ? with or without a heat sink?
Greg
Greg
i stick to surface mount and use the pcb as a heat sink. you can do this with through hole components also by bending it over and having a large copper pad on the pcb. if current and voltage drop make it so a lot of power is dissipated then you will want to add a heat sink or consider using a different regulator.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
