Good deal on large solderless breadboards
We got some big solderless breadboards in from China.
It took about 2 weeks to arrive and they are very nice!
16.99 ea and free shipping
Plastic feet on the bottom...the individual boards are screw
mounted not adhesive mounted. This means you can keep
an extra unit with a set of 4 and swap boards in if they
wear out (everything wears out) this means they will have
a longer life. The base is non-conductive heavy plastic.
I'm going to remove one of the terminals from the top
and mount a small board with a dil propeller in a zif along
with 3.3v regulator, xtal etc.
These come with a huge allotment of flexible jumper
wires with pins mounted on both ends. I expected just
a few but they send a bunch of them.
cgi.ebay.com/2-860-Tiepoint-Solderless-Breadboard-Includes-Jumpwires_W0QQitemZ350214248441QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item518a6557f9&_trksid=p3911.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|240%3A1307|301%3A1|293%3A2|294%3A50
There's nothing like a new idea and a warm soldering iron.
I bought a big lot(qty 100) 2000V, 0.33uf ceramic caps from them which I'm using in my marx generator(series connected).
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Or I could just put the beer in a bucket of water and ice, but what's the fun in that?
For my lunchbox I will be using a small foam cooler. Will cut out a square for the peltier. Will mount cpu heat sink inside with guard to keep stuff from hitting fan and large passive heat sink outside. I will be using the 18V Makita drill batteries to power it. 3Ah battery should keep cool for the day easily since I am using a fairly well insulated case to start and 4 thermistor to keep the temperature to control the cpu fan and peltier to keep about 3C. I am also going to add a 12v plug so I can plug in my BlackBerry Cellphone charger.
Rough cut with a hacksaw and clean up with a utility knife.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
