The Hot-Air (re)Work & SMD Soldering Thread
CounterRotatingProps
KEYWORDS: SMD, hot air, hot-air rework,·stencil, soldering, solder paste,·soldering tools, soldering equipment, solder wick, toaster oven, how do I solder SMD
This thread is intended to help you learn - and to encourage you to·try -·SMD (Surface Mount Devices) methods.
Don't worry: many·of us here feel·a bit intimidated trying to work·with such small components.
If you would like to learn more about·SMD techniques, please·post your questions in this thread.
If you know and use these techniques, please·do contribute your tips and experience. Links are always welcome.
Discussion and direct help very much wanted.
thanks for your assistance!
-Howard in Florida
(an SMD N00B [noparse]:)[/noparse]
[noparse]/noparse][u]EDIT ---[color=white]·[/color][b]check back[color=white]·[/color]here for new links[color=white]·[/color]appended as we[color=white]·[/color]find them[/b] ---[/u
HollyMinkowski found a basic hot air station for USD 118 delivered for a 100% rated seller --- and look through this thread for other deals and links.
stores.shop.ebay.com/TheBestLuckCorner__W0QQ_armrsZ1
From a tip Mike Green gave about an SMD·tutorial on SparkFun,·we found this:
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=36
06/18/09 = Drag soldering technique:
http://www.howardelectronics.com/jbc/dragsoldering.html
06/20/09 = Zyphertronics desoldering·system (watch the interesting video, mid page):·
http://www.ameritronics.com/lowmelt_desolder_wire_de-solder_removes_chip_quickly.htm
06/21/09 = SMD,·a 10,000 foot view, but does review the various techniques used in solder (re)work:
http://en.wikipedia.org/wiki/Surface-mount_technology
mctrivia's link to a cool [noparse]:)[/noparse] DYI reflow soldering oven (see links at page bottom for some GPL Linux electronics tools):·
http://web.interware.hu/lekovacs/reflow_oven/index.html
Oven from the links at the bottom of ^that page --- (or, when your spouse asks, "hey, where'd the toaster oven go??"):
http://www.seattlerobotics.org/encoder/200006/oven_art.htm
7/14/09 From the prop forum, discussion about solder pastes
http://forums.parallax.com/showthread.php?p=806251
_____________________________________________________________________________·
Link from·the Propeller forum,·titled "BOOST Propeller Chip?", that spawned this thread:
http://forums.parallax.com/showthread.php?p=816568
Post Edited (CounterRotatingProps) : 7/14/2009 8:56:41 PM GMT
-Howard in Florida
Stencils cost $20
Toaster I paid $50
Past I forget but not expensive and does lots of boards.
Hoe to use.
Place stencil over board
Put past on 1 side.
Use old credit card to draw paste over board.
Remove stencil
Place parts
Pre heat toaster to 200 f
Let boards sit for 4 min
Turn temperatur to 325 f
When elements turn off time 2 min
Turn temp to 450f
When solder starts to go molten time 30 second
Turn off
Bang toaster gently to let parts self seat.
Open door and give 10 min to cool down.
If no stencil use syringe solder.
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
thanks !
-H
here is an example of the file they need. this file makes the stencil for the top of all my propmodules.
what would you like to know about them?
Post Edited (mctrivia) : 6/19/2009 1:21:17 AM GMT
Pretty much all you need to know. Just get a hot air station and a big roll
of solder wick and you are good to go.
The Hot Air station I gave the link for in China looks pretty much the same
as the one at SparkFun but at about 1/2 the cost delivered.
If you get it do be sure and get the 10pak of tips for the iron at the same time
for $8 as shipping is free for them if ordered with the station.
A good way to learn is to take the boards out of defunct electronics and practice
creating and solving problems using the sm devices that are on all circuit boards.
And do be sure to not breath too much of the stinky smoke you make when
practicing
I like the looks of the one above better though but this might be fine
and UPS delivery from CA is included in the price.
cgi.ebay.com/SMT-SMD-Hot-Air-Desolder-Rework-Station-Welder_W0QQitemZ200292257268QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea2594df4&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A2103|240%3A1318|301%3A1|293%3A1|294%3A50
> I looked at that SMD tutorial at SparkFun and I think it's great!
Yes, they have a lot of good things there indeed.
What do you all think of the soldering tweezers?
Post Edited (CounterRotatingProps) : 6/20/2009 7:08:24 PM GMT
syringe: www.ameritronics.com/lead-free_solder_paste_RoHS_nolead-10cc.htm
@mctrivia: what's 'sering' solder - is it some form of solder paste?
RE: Lead-free solder
With all the RoHS stuff on the market, I've been wondering what happens if you accidently try to solder a lead-free component with leaded solder, or vice versa --- does it make an unusable mess, cold joints, etc?
syringe solder was a type. it is a suspended solder that comes in a syringe to allow for accurate placement.
I agree whole-heartedly with this ... just destroyed two of them this week [noparse]:)[/noparse]
Bought a $30 600F heat-gun from Halted Specialties yesterday. Works great for removing parts.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
I was just thinking about heatguns instead of the rework stations.
Obviously a heatgun is a tad more out of control
> just destroyed two of [noparse][[/noparse]mctrivia's boards] this week [noparse]:)[/noparse]
Was the destruction before or after (that is WITH) the heat gun??
Worked better than the toaster oven for me [noparse]:)[/noparse] Less waiting, power consumption, localized airflow, etc....
I bought those two boards specifically to experiment with QFN Propellers.
The placement silk-screen is priceless ... I have some boards without it, and I screwed with one all day.
My question is: once you place the chip for the oven, how do keep it from wondering out of place?
--Steve
Surface tension will make the pins want to center themselves on the pad. As long as you are not off by more then 1.5x the pad spacing it should work. This is the reason for the tap the oven when done instruction it helps the chips move to the center of the pads.
OK, for those of us who've never done this...
it looks like many of the stencils are made of a tradename polyimide film called "Kapton" 1), which is then cut using a laser, leaving reveals.
Does the stencil make the pads?
1)http://www2.dupont.com/Kapton/en_US/
see also:
http://www.professionalplastics.com/KAPTONFILMPOLYIMIDE
Post Edited (CounterRotatingProps) : 6/20/2009 8:02:41 PM GMT
mctrivia, you mentioned BGA chips just a bit ago,
can you soldering one of those in your easy-bake [noparse]:)[/noparse] oven ? They look pretty intimidating!
I love this and welcome any info available ,, Mike should make this a sticky
I would love more info on solder paste?? and Stencils,, is it possible to just handle the majority of SMT stuff with just using hot air re-work and solder paste ,, Do you have to use stencils , The reason I ask it looks kind of hard to fiddle with placemnet of some of the stencils I have seen unless I am looking at the wrong thing,, I also tried the heat gun it was like shooting a mouse with a bazooka even with the differant tips my biggest problem is how to tell when the solder paste has really melted most the time if I Wait for it to get shiny the circuit board starts to turn black and smoke
Post Edited (mikediv) : 6/21/2009 1:40:41 AM GMT
I am currently offering a bulk discount on my pcb to the first 4 that take advantage. 20PCB for $50. If you order 10 PCB on my site and mention this deal in the notes I will send you 20.
Greg
@mikediv: LOL ! Hopefully this thread will make working with SMD more like shooting fish in a barrel [noparse]:)[/noparse]
- H
That looks like a really good hot air station.
Nice that they sell replacement heaters...wonder if they also
sell replacement membrane air pumps? The lady in China sells
parts but I have no idea how reasonably.
A filter for the stinky smoke is a must IMO!
I usually go into a small room at work that has outside air pumped into these light weight
hood things you wear.... you can't smell any smoke because you are getting external air
through a flexible plastic hose...I hate smoke! they laugh at me for using the room just to
avoid solder smoke...usually they spray coatings onto stuff in there.
