Help!!! Sd adapter!!!
I made an sd card adapter but it does not work!· I have tried both femtobasic and propdos on it and it doesn't work...· I have a "Card Inserted" LED that has the cathode connected to the (-) supply and the anode is connected to the pins on the SD card that are for ground.
The wierd thing is, the LED is on for a second when the demo board is turned on, but once the program gets to the point where it's trying to connect to the SD card, the LED goes off.
Why?!?!?!?·
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Why?!?!?!?·
Thanks.
Better check your card on a PC and see if it still works!
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
One thing--Do I need to have files on the SD card in order for FemtoBasic or PropDOS to work...? I don't have a single file on it, so....
Thanks.
Read the contents of
http://tomas.rokicki.com/fat16work/README.txt
thoroughly and let me know if you still have questions.
I don't know if I did it right... I will check if it works now and get back to you.
Also, I just went to cmd prompt and I think I got it formatted into FAT16 with 32k in each allocation unit...
I will keep you all posted on everything.
On my last board, I had some issues with the SD checking routine not
seeing the SD card on bootup and reporting an error. These routines
are in both Femtobasic and Propdos. I switched them out with a
"reboot" when the error was detected and bypassed the issue.
It seems that the card isn't startup up as fast as the rest of the
project, and given a reboot it seems to catch up the 2nd time around.
I haven't had time to debug the board with all the expo stuff going on.
OBC
New to the Propeller?
I think I know...
I got a Kingston 2GB *Elite Pro*
It said in the description that it has faster data transfer and such... My dad thinks it's autoformatted or something and that it can't be changed, so it's impossible to use....
Lucky me... Now that I get something that isn't faulty, I can't use it!
The weirdest thing is.... the SD ccard worked the first time I tried to work it on my demented breakout board setup....
In that section that says "No, it's not okay" I put a "reboot" command.
OBC
I'm trying my adapter with all my props now. First is my Gadget Gangster Boss Board, then my two prop protos. One more quesiton--is there a program for the Basic Stamp 2 that lets it acces SD...? That would be a nice way to test it...
Thanks.
|···········\________________ /··············|
|···· ________ ____·_____________······|
|·· \_____________· ____________/···· |
|_|···· ||· ·||· || · || · ||··||··|| · ||· || ··|_|
········· 1···2·· 3··· 4·· 5·· 6·· 7··· 8·· 9
1 - 10k pull·up to 3.3v; no connection to prop
2 - 10k pull up to 3.3v; connected to pin 3 of prop demo board
3 - 10k pull up to 3.3v; connected to pin 2 of prop demo board
4 - connected to pin 7 and (+) of Card Inserted LED, whose (-) lead is connected to Vss
5 - connected to Vdd
6 - 10k pull up to 3.3v; connected to pin 1 of prop demo board
7 - connected to pin 4 and (+) of Card Inserted LED, whose (-) lead is connected to Vss
8 - 10k pull up to 3.3v; connected to pin 0 of prop demo board
9 - 10k pull up to 3.3v; no connection to prop
Okay, there's the configuration of my SD card slot.
Can you PLEASE see if that connection is correct...?
Thanks.
Step 1:· Remove LED
Step 2:· Check this page for proper wiring:
http://www.rayslogic.com/propeller/Programming/SD_Card/SD_Card.htm
I will check the circuit now.
Thanks.
Right here.
www.warrantyvoid.us/tiki-index.php?page=Interfacing+SD+media
Format complete.
1,966,768,128 bytes total disk space.
1,966,768,128 bytes available on disk.
32,768 bytes in each allocation unit.
60,021 allocation unita available on disk.
16 bits in each FAT entry.
Volume serial number is 9C8B-373C
What in the world does all of that mean???
Thanks.
"32,768 bytes in an allocation unit" means that the smallest file
will be at least 32,768 bytes. No big deal for what we are doing.
OBC
Also, I know it isn't the prop itself, because I tried it on my dip as well...
Gwahh....
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Hope that helps...
OH.... Well..... I don't have too much money that I am at liberty to spend..... I am trying to save at least %20 of what I earn from Gadget Gangster, so I have about $15 left in my PayPal.... I don't know....
How much is the ucontroller adapter again...?
Thanks.
So is that really all there is to do...?
Thanks.
you can also upload very high res photos and copies of exact code and somone may find problem.
