WAITPEQ Timing, Setup & Hold Times, etc.
Phil Pilgrim (PhiPi)
Chip,
Given this code:
and this diagram:
can you indicate where ina is read by the mov? What are the port pin setup and hold times for the waitpeq relative to the clock? For the mov?
Phil
Given this code:
[b]waitpeq[/b] one, one
[b]mov[/b] dest, [b]ina[/b]
one [b]long[/b] 1
and this diagram:
Phil
1+1=10
I'll try to answer part of this........... to the best of my recollection:
When the waitpeq instruction is started, it stalls after its second clock. Then when the condition becomes true, the rise of A0, it takes three more clocks to finish the instruction, so that would consume clocks a,b,c. As Paul said, the next instruction wil read the port during the third clock, f.
At this moment, I'm not recalling if instructions conclude on the rise or fall of the clock, but I'll check that out, and confirm my findings for you later today.
Regrettably, I don't know the set-up and hold times; it would take a bunch of work to determine that emperically.
Cheers,
Peter (pjv)
0) read source N
1) read destination N
2) read instruction N+1
x) any wait cycles go here (0...infinity clocks)
3) write destination N (N=N+1, goto 0)
So, the source is read 3 cycles before the destination result it written. This timing scheme gives the ALU·two clocks in which to settle after I, S, and D have been read.
Chip Gracey
www.fd.com.my
www.mercedes.com.my
1. Shouldn't 2) be read instruction N+1 and execute N ?
2. For me this sounds like the start of a PASM needs one additional instruction because the first instruction is fetched with the first cycle but executed with the second cycle. So, is the PC maybe set to adress 511 at the beginning of PASM code execution?
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Don't agree with that.
0) To execute the instruction you need source and destination. If you say AND x,y it makes no sense to start execution if you did not read x yet.
1) execute the instruction here would mean that you don't have to flush the pipeline for conditional jumps because in step 2 it would be clear which instruction to fetch next.
So, for me 2) is the place where I'd expect the execution.
do not forget this discussion we had last year:
http://forums.parallax.com/showthread.php?p=725782
With oscillograms and all
Visit the home of pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
