BOOST Propeller Chip? — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2009-06-21 21:05 in Propeller 1
How can I boost the Propeller chip to 200 Teraflops (200 trillion calculations per second)?
humanoido
    edited 2009-06-16 03:41
    The best you can do is to cool it to -55C, run it at +3.6V Vdd. You may be able to run it with a 140MHz system clock according to the datasheet (and the testing that went into it). Each cog will do 35 x 10^6 instructions per second. With 8 cogs, you'll get an aggregate 280 x 10^6 or 0.28 x 10^9 instructions per second (0.28 Teraflops).
  • RossHRossH Posts: 5,735
    edited 2009-06-16 03:51
    C'mon Mike, don't stop now!
    ... and then you just get 715 of them, and then ...
    Ross.
  • BradCBradC Posts: 2,601
    edited 2009-06-16 03:57
    humanoido said...
    humanoido
    While you are there, how can I make my 1982 Volvo do 300 MPH ?
    Eccles : How do I open the door?
    Bluebottle : You turn the knob on your side
    Eccles : I haven't got a knob on my side!
    edited 2009-06-16 03:59
    Ross,
    He did ask about boosting "the Propeller chip", not "Propeller chips". It would certainly be easy enough to create a 10 x 10 x 10 cube, particularly if you use SMT parts instead of PDIP packaging. It would also be fairly straightforward to substitute Spin Stamps for the Basic Stamps in the Basic Stamp Supercomputer. You wouldn't get quite the same throughput, but 10 to 12 Spin Stamps would get you through the Teraflop barrier.
  • mparkmpark Posts: 1,336
    edited 2009-06-16 04:28
    Aren't flops floating-point ops?
    edited 2009-06-16 04:30
    BradC said...
    edited 2009-06-16 04:36
    nope. will not reach 300MPH. terminal valocity is way below that.
    propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-06-16 04:37
    mctrivia said...
    Duh - you've gotta take your foot off the brake!
    edited 2009-06-16 04:54
    I computed with propgalore boards i could get 16384 cogs in a 7"x7"x7" cube all running lock steped together.
    at 80MHz you get 327.7 GIPs
    at 140Mhz you get 573.4 GIPs
  • simonlsimonl Posts: 866
    edited 2009-06-16 19:36
    ElectricAye said...
    mctrivia said...
    @humanoido: Looks like you're gonna make a PSS then? I've wired-up 6 prop's, but haven't got around to coding yet shakehead.gif
    Cheers,
    Simon
    www.norfolkhelicopterclub.com
    “Before you criticize someone, you should walk a mile in their shoes. That way when you criticize them, you are a mile away from them and you have their shoes.” - Jack Handey.
  • RaymanRayman Posts: 16,266
    edited 2009-06-16 20:34
    Yes, flops are floating-point ops per second, substantially less than IPS (instructions per second) with the Prop!
    mpark said...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    edited 2009-06-16 21:44
    A more realistic goal would be to emulate the performance of some of the early supercomputers
    using the propeller.
    I looked up the Cray1 and it was a 64bit 160MIPS system capable of about 100 MFLOPS.
    The Cray1 would be easily matched by a propeller system and it was worth 5 - 8 million
    in mid 70s dollars.
    A multi-chip propeller system could probably reach a few billion floating point operations/sec.
    But it would be cheaper and easier to use several overclocked quad core motherboards running Linux
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2009-06-17 07:18
    HollyMinkowski said...
    in mid 70s dollars.
    Using the assembly floating point routines the time for a floating point add is 4.7us and for for a multiply 10.5us. If we take the average of those two we end up with 7.6us which ends up to be about 130,000 flops. Times this by 8 cogs and you get about 1 MFLOP. So, to get to the 100 MFLOPS you are going to need about a 100 props and then you will still only be working with 32 bit numbers and not 64 bit numbers. Like you say it would be a much better idea would be to just get any modern pc including a netbook. That should be able to do it easily.
    edited 2009-06-17 14:47
    ElectricAye said...
    mctrivia said...
    I'm gone to Norwalk for a day and I miss this! ROFLOL!
    {BTW: It's time to sign up for UPENE, gang!}
    OBC
    New to the Propeller?
    edited 2009-06-17 16:36
    Mike Green said...
    The single Propeller specification is 160Mips. Can you please explain how ten (or 12) Spin Stamps can get into the Teraflop range? Thanks.
    humanoido
    Post Edited (humanoido) : 6/18/2009 11:09:03 AM GMT
    152 x 182 - 28K
    edited 2009-06-17 16:46
    Oooops. In my haste to sound optimistic, I got my powers of 10 wrong. You're correct, it's 2 Gigaflops (if you count integer arithmetic as a flop), not 2 Teraflops. A 10 x 10 x 10 cube would give you 1/5 of a Teraflop (if you count instructions per second).
    edited 2009-06-18 03:38
    That's ok, I actually liked the more optimistic reply better. Thank you for the ideas. This thread is filled with good ideas. I have seen SMT chips and the pins are so tiny, it's unlikely I could solder those to a board, and certainly not on the order of 1,000. When I go with this project, how can soldering be accomplished? Thanks.
    humanoido
    edited 2009-06-18 04:07
    SparkFun has a "course" on SMT soldering. It takes practice and experience. I've not done much myself ... old eyes and no depth perception.
    For something on the order of a stack of boards, you should probably use a temperature controlled oven to do a whole board at a time once you've placed the parts in position. SparkFun has a description of how to make one from a toaster oven. I think Beau posted a project once upon a time for a Stamp controlled oven.
    edited 2009-06-18 04:27
    I use a toaster oven. My propmodule pcb are a good practice system.
    Other option pay someone.
    For first 4 orders buy 10 pcb get another 10 free. Put offer code 42f in checkout notes.
    edited 2009-06-18 04:43
    Get a hot air rework station and a set of nozzles for it.
    You can get a nice one really cheap direct from China (Ebay)
    The hot air makes it easy to remove and solder sm chips.
    Makes it easy to pull the part back off, clean up, and try again
    I find a USB camera to be useful for giving a magnified view of
    a circuit board. One of the rework stations at work has a microscope
    on it.
  • SRLMSRLM Posts: 5,045
    edited 2009-06-18 04:55
    I really like working with a hot air station for the (very few) SMD soldering that I've done. There's also a member on these forums (name is something like "Lil' Bro's ...") that will assemble small runs of SMD boards. I understand that they're very reasonable.
    edited 2009-06-18 04:58
    yes James Long is very reasonably priced.
  • James LongJames Long Posts: 1,181
    edited 2009-06-18 05:17
    SRLM said...
    Yes we are around......haven't been on the forum much lately....had our main company server go down....and still working to get it back to 100%.
    If you want a quote....just email me from the forum (email is accessible here), and we can quote the job. There is a lot of information required to get a quote....but we try to make it as painless as possible.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
    edited 2009-06-18 07:05
    Now if I could just add this to my matchbox sized YottaByte disk drive now (instead of the future) smile.gif
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
  • Chris MicroChris Micro Posts: 160
    edited 2009-06-18 17:54
    If one propeller has a power dissipation of 1 Watt you would have a total of 16KW.
    How do you want to cool it? Do you need it as central heating?
    edited 2009-06-18 18:05
    At max draw it would be only 2kW
    I find though prop normally runs much less more like 8mW/cog. So more like 150W. By the way new computer power supplies now sell in the 1.5kW range. Cooling would not be to bad good fan will do.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-06-18 20:46
    http://www.youtube.com/watch?v=3YVSXRETml4
    ( Yeah, I know I posted that before, but it just seemed too appropriate :-P )
    zettaFLOPS 1021
    yottaFLOPS 1024
    wholeLottaFLOPS 10210
    Seriously though Humanoido, like Holly suggested, why not use a more appropriate platform? Several Nvidia GPUs put together can do some heavy number crunching, like this:
    http://www.dvhardware.net/article27538.html
    @Holly, Mike Green, SRLM, mctrivia - thanks for the tips on hot-air work. I've been looking into this for the first time. Mike, I'm like you, I've been shying away from them because of eyesight. Holly, your idea of a web-cam microscope has just bubbled to the TOP of my project to-do list - thx!· If I started a 'hot-air re/work' thread in the sandbox, would you all jump in a bit?
    cheers
    - Howard
    "This device contains recyclable materials, which can be re-decomposed
    and re-integrated into brand new marvels... We strongly encourage you
    to contact the provided information and recycle yourself always. "
    edited 2009-06-18 23:02
    @CounterRotatingProps
    There is an Ebay seller named Mary Li Wang in Guangdong China that sells a basic hot air station for 118.00 delivered.
    She has a 100% seller rating.
    stores.shop.ebay.com/TheBestLuckCorner__W0QQ_armrsZ1
    You can buy extra iron tips and nozzles that will ship free at the same time as the station... $8 each.
    She even has a BGA rework station with scope for just $400
    edited 2009-06-18 23:45
    Great Holly, thanks!
    I've copied that over to the Sandbox where I've started a new topic, called "The Hot-Air (re)Work & SMD Soldering Thread " [noparse]:)[/noparse]
    http://forums.parallax.com/forums/default.aspx?f=15&m=360823
    If you know about hot-air rework, or SMD techniques, PLEASE drop in and contribute to that thread!
    thanks,
    - Howard
    [noparse]/noparse][noparse][[/noparse] after this short thread interruption ... we now return you to your regularly scheduled thread topic
    edited 2009-06-21 19:25
    Mike Green said...
    ....·SparkFun has a description of how to make one from a toaster oven. I think Beau posted a project once upon a time for a Stamp controlled oven.
    Hi Mike, I've done some extensive searches, and Beau doesn't recall this. Do you happen to remember possible key words for a better search?· (for SMD techniques mentioned above.)
    thanks
    - Howard
