The best you can do is to cool it to -55C, run it at +3.6V Vdd. You may be able to run it with a 140MHz system clock according to the datasheet (and the testing that went into it). Each cog will do 35 x 10^6 instructions per second. With 8 cogs, you'll get an aggregate 280 x 10^6 or 0.28 x 10^9 instructions per second (0.28 Teraflops).
Ross,
He did ask about boosting "the Propeller chip", not "Propeller chips". It would certainly be easy enough to create a 10 x 10 x 10 cube, particularly if you use SMT parts instead of PDIP packaging. It would also be fairly straightforward to substitute Spin Stamps for the Basic Stamps in the Basic Stamp Supercomputer. You wouldn't get quite the same throughput, but 10 to 12 Spin Stamps would get you through the Teraflop barrier.
“Before you criticize someone, you should walk a mile in their shoes. That way when you criticize them, you are a mile away from them and you have their shoes.” - Jack Handey.
A more realistic goal would be to emulate the performance of some of the early supercomputers
using the propeller.
I looked up the Cray1 and it was a 64bit 160MIPS system capable of about 100 MFLOPS.
The Cray1 would be easily matched by a propeller system and it was worth 5 - 8 million
in mid 70s dollars.
A multi-chip propeller system could probably reach a few billion floating point operations/sec.
But it would be cheaper and easier to use several overclocked quad core motherboards running Linux
to achieve high performance
HollyMinkowski said...
in mid 70s dollars.
Using the assembly floating point routines the time for a floating point add is 4.7us and for for a multiply 10.5us. If we take the average of those two we end up with 7.6us which ends up to be about 130,000 flops. Times this by 8 cogs and you get about 1 MFLOP. So, to get to the 100 MFLOPS you are going to need about a 100 props and then you will still only be working with 32 bit numbers and not 64 bit numbers. Like you say it would be a much better idea would be to just get any modern pc including a netbook. That should be able to do it easily.
Mike Green said...
The single Propeller specification is 160Mips. Can you please explain how ten (or 12) Spin Stamps can get into the Teraflop range? Thanks.
humanoido
Post Edited (humanoido) : 6/18/2009 11:09:03 AM GMT
Oooops. In my haste to sound optimistic, I got my powers of 10 wrong. You're correct, it's 2 Gigaflops (if you count integer arithmetic as a flop), not 2 Teraflops. A 10 x 10 x 10 cube would give you 1/5 of a Teraflop (if you count instructions per second).
That's ok, I actually liked the more optimistic reply better. Thank you for the ideas. This thread is filled with good ideas. I have seen SMT chips and the pins are so tiny, it's unlikely I could solder those to a board, and certainly not on the order of 1,000. When I go with this project, how can soldering be accomplished? Thanks.
SparkFun has a "course" on SMT soldering. It takes practice and experience. I've not done much myself ... old eyes and no depth perception.
For something on the order of a stack of boards, you should probably use a temperature controlled oven to do a whole board at a time once you've placed the parts in position. SparkFun has a description of how to make one from a toaster oven. I think Beau posted a project once upon a time for a Stamp controlled oven.
I really like working with a hot air station for the (very few) SMD soldering that I've done. There's also a member on these forums (name is something like "Lil' Bro's ...") that will assemble small runs of SMD boards. I understand that they're very reasonable.
SRLM said...
Yes we are around......haven't been on the forum much lately....had our main company server go down....and still working to get it back to 100%.
If you want a quote....just email me from the forum (email is accessible here), and we can quote the job. There is a lot of information required to get a quote....but we try to make it as painless as possible.
I find though prop normally runs much less more like 8mW/cog. So more like 150W. By the way new computer power supplies now sell in the 1.5kW range. Cooling would not be to bad good fan will do.
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Seriously though Humanoido, like Holly suggested, why not use a more appropriate platform? Several Nvidia GPUs put together can do some heavy number crunching, like this:
@Holly, Mike Green, SRLM, mctrivia - thanks for the tips on hot-air work. I've been looking into this for the first time. Mike, I'm like you, I've been shying away from them because of eyesight. Holly, your idea of a web-cam microscope has just bubbled to the TOP of my project to-do list - thx!· If I started a 'hot-air re/work' thread in the sandbox, would you all jump in a bit?
cheers
- Howard
"This device contains recyclable materials, which can be re-decomposed
and re-integrated into brand new marvels... We strongly encourage you
to contact the provided information and recycle yourself always. "
Mike Green said...
....·SparkFun has a description of how to make one from a toaster oven. I think Beau posted a project once upon a time for a Stamp controlled oven.
Hi Mike, I've done some extensive searches, and Beau doesn't recall this. Do you happen to remember possible key words for a better search?· (for SMD techniques mentioned above.)
... and then you just get 715 of them, and then ...
Ross.
Catalina - a FREE C compiler for the Propeller - see Catalina
While you are there, how can I make my 1982 Volvo do 300 MPH ?
Eccles : How do I open the door?
Bluebottle : You turn the knob on your side
Eccles : I haven't got a knob on my side!
Drop it from an airplane.
Duh - you've gotta take your foot off the brake!
at 80MHz you get 327.7 GIPs
at 140Mhz you get 573.4 GIPs
@humanoido: Looks like you're gonna make a PSS then? I've wired-up 6 prop's, but haven't got around to coding yet
Cheers,
Simon
www.norfolkhelicopterclub.com
in mid 70s dollars.
I'm gone to Norwalk for a day and I miss this! ROFLOL!
{BTW: It's time to sign up for UPENE, gang!}
OBC
New to the Propeller?
humanoido
humanoido
Other option pay someone.
For first 4 orders buy 10 pcb get another 10 free. Put offer code 42f in checkout notes.
You can get a nice one really cheap direct from China (Ebay)
The hot air makes it easy to remove and solder sm chips.
Makes it easy to pull the part back off, clean up, and try again
I find a USB camera to be useful for giving a magnified view of
a circuit board. One of the rework stations at work has a microscope
on it.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
If one propeller has a power dissipation of 1 Watt you would have a total of 16KW.
How do you want to cool it? Do you need it as central heating?
http://www.youtube.com/watch?v=3YVSXRETml4
( Yeah, I know I posted that before, but it just seemed too appropriate :-P )
zettaFLOPS 1021
yottaFLOPS 1024
wholeLottaFLOPS 10210
http://www.dvhardware.net/article27538.html
cheers
- Howard
There is an Ebay seller named Mary Li Wang in Guangdong China that sells a basic hot air station for 118.00 delivered.
She has a 100% seller rating.
stores.shop.ebay.com/TheBestLuckCorner__W0QQ_armrsZ1
You can buy extra iron tips and nozzles that will ship free at the same time as the station... $8 each.
She even has a BGA rework station with scope for just $400
I've copied that over to the Sandbox where I've started a new topic, called "The Hot-Air (re)Work & SMD Soldering Thread " [noparse]:)[/noparse]
http://forums.parallax.com/forums/default.aspx?f=15&m=360823
If you know about hot-air rework, or SMD techniques, PLEASE drop in and contribute to that thread!
thanks,
- Howard
[noparse]/noparse][noparse][[/noparse] after this short thread interruption ... we now return you to your regularly scheduled thread topic
thanks
- Howard
