SD Pinouts
can someone give me a link to a forum thread or upload a picture of the pinouts of an sd card?
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
rayslogic.com/propeller/Programming/SD_Card/SD_Card.htm
START:·
>Saving Data. . . .
>Signing OFF
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
START:·
>Saving Data. . . .
>Signing OFF
I agree, if the LED is going out, there is a serious issue to find.
OBC
New to the Propeller?
You might want to put it in your computer in see if it still works...
It is an offbrand SD, and I would use another, but i dont want to ruin a $20 SD for my own enjoyment.
Anyway, I'll just recheck the connections accoring to the cookbook ,(Very nice material I must say, OBC),
and try it again.
P.S. For those who are intrested in what I am doing, I am trying to run the Full screen editor.
(yes, I can just comment out the SD card lines that check if it's there, but I want to see it run with the SD.
START:·
>Saving Data. . . .
>Signing OFF
if the prop bd is ok until the SD is pluged in, are all your SD VDD and VSSs te right way around?
There are two VSS pins and one VDD, as far as I can remember, is there a combo where the supplies are shorting throgh the cards connections??
