SD Pinouts — Parallax Forums
SD Pinouts
ProcessingData...ProcessingData... Posts: 208
edited 2009-06-13 20:10 in Propeller 1
can someone give me a link to a forum thread or upload a picture of the pinouts of an sd card?
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
    edited 2009-06-12 22:17
    I just put "sd pinouts" into google and loads came up. I have used pinouts.ru b4
  • ProcessingData...ProcessingData... Posts: 208
    edited 2009-06-12 23:41
    Okay, I've got the pinouts, but I have a question, does the sd need power applied to the VDD and VSS pins to work?
    START:·
    >Saving Data. . . .
    >Signing OFF
  • RaymanRayman Posts: 15,886
    edited 2009-06-12 23:43
    You do need the power. I no longer think you need the pull-ups though...
    edited 2009-06-13 01:49
    When i apply power to the sd, the power led goes out. The sd is still good. Could it be shorting?
    START:·
    >Saving Data. . . .
    >Signing OFF
    edited 2009-06-13 02:19
    That does sound particularly grave...· Your power LED should not go out when connected to the SD card...
    edited 2009-06-13 02:28
    There is a page on SD here. that might help.
    I agree, if the LED is going out, there is a serious issue to find.
    OBC
    New to the Propeller?
    edited 2009-06-13 10:28
    Once, I did have an SD card that would do that... But, I think it was angry at me for powering it once or twice with +5V...
    You might want to put it in your computer in see if it still works...
    edited 2009-06-13 19:09
    I did plug it in to my computer, and it still works. I checked and rechecked my hookup pins and wires and soldering. It still shorts when I plug it in. hmmm....
    It is an offbrand SD, and I would use another, but i dont want to ruin a $20 SD for my own enjoyment. wink.gif
    Anyway, I'll just recheck the connections accoring to the cookbook ,(Very nice material I must say, OBC),
    and try it again.
    P.S. For those who are intrested in what I am doing, I am trying to run the Full screen editor.
    (yes, I can just comment out the SD card lines that check if it's there, but I want to see it run with the SD.
    START:·
    >Saving Data. . . .
    >Signing OFF
    Just a surgestion
    if the prop bd is ok until the SD is pluged in, are all your SD VDD and VSSs te right way around?
    There are two VSS pins and one VDD, as far as I can remember, is there a combo where the supplies are shorting throgh the cards connections??
