Largos update, Las information (large model OS, assembler) — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2009-06-24 21:01 in Propeller 1
Hi,
I've started the documentation pages for both Largos (my LMM based OS for the Propeller) and Las (my LMM assembler for Largos) at my site; links in my sig.
For now I posted
- the initial Largos feature set, and a simple performance benchmark result for message passing (almost 2300 empty messages processed per second by the prototype Spin kernel)
- the initial Las feature set, definition of Las pseudo ops, and "coming soon" features for it.
I am taking comments and suggestions for the posted information on both Largos and Las, either here, or on my site (you have to register to post, I do this to avoid spam)
I will mostly post Largos and Las updates to my site as I don't want to clutter this forum.
Now back to working on Las and Largos...
Bill
Las - Large model assembler for the Propeller (alpha version this week)
Largos - a feature full nano operating system for the Propeller
www.mikronauts.com - a new blog about microcontrollers
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2009-06-09 08:01
    If your prototyping it in spin does that mean that there will be a version that will compile with the propeller tool/bst or will it all need to be done with Las (only ask because I use a Mac)?
    You also mentioned loading spin applications. Will they have access to the standard os libraries for using i/o and stuff?
    edited 2009-06-09 13:31
    Good questions... the prototype, compiled with the Propeller tool, has actually been performing so well that it may be worthwhile to keep it going in its own right... possibly calling it SmallOS <grin>.
    Please note I intend to get Las running on my Mac and my Ubuntu box as well.
    Spin applications running under Largos will have to be slightly modified. They will have to:
    - include the "os" object to get access to all of the OS capabilities (for I/O, file system, loading drivers, etc)
    - they should not set _clkmode and _xinfreq, the OS does that - they can read them from the hub
    - they should not include drivers available in the OS, but use the OS services
    If the app obeys the rules above, it should just be a matter of compiling them to a .binary file, as Largos will load .binary files.
    stevenmess2004 said...
  • trodosstrodoss Posts: 577
    edited 2009-06-09 13:57
    @Bill,
    Sounds like a great project! Does each driver/service that gets loaded into the OS run in a separate cog? I would imagine that you would also have to take into consideration how many driver/services would be 'in memory' when your code was running.
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-06-09 22:23
    Great software architecture, Bill. And great coding!
    JMH
  • hinvhinv Posts: 1,272
    edited 2009-06-10 00:23
    Hi Bill
    I was hoping someone would do a 'UNIX"ish OS. I have been a unix geek for 20 years and the commands roll off my fingers.
    What are the hardware requirements?
    Is there a download link, or is this just a preteaser?
    Doug
    Post Edited (hinv) : 6/10/2009 12:29:29 AM GMT
    edited 2009-06-10 03:00
    No downloads yet, it is not complete/good enough yet.
    There is some more info on both Largos and Las on my blog, I'll keep updating those pages with progress reports. I hope to demo both at UPEW - rather, I WILL demo both, in whatever shape they are in by that time smile.gif
    Largos is quite Unix-y on the surface, here are some of the (implemented) shell commands that already work (in the monolithic shell version, I have to still rip it apart and make it into a real Largos client):
    cat cd du df ls rm rmdir mv mkdir mkfs pwd touch (additional commands coming soon)
    here are the currently working stdio calls:
    putc getc puts gets getline (with backspace support)
    the file system calls are close to the Unix ones as well.
    It's looking like the initial version will have about a 10KB hub footprint, however that includes 2KB for a buffer for loading kernels, drivers, etc - and as I re-write it in Las, I expect the footprint to drop to around 8KB. Large spin programs that use many drivers will actually have more free memory under Largos, as it loads the drivers directly from flash, so they are not resident in the hub after they are started up.
    Bill
    hinv said...
    Hi Bill
    Doug
    edited 2009-06-10 03:02
    Thanks!
    Most drivers will run as a separate cog, but some are shared - there is a combined keyboard/mouse driver I intend to port to Largos, and there is the quad serial. I am also thinking about combining my SPI and I2C drivers into one cog. Drivers/services don't have a footprint in the hub after being loaded - other than a 16 byte mailbox smile.gif
    trodoss said...
    @Bill,
    edited 2009-06-10 03:03
    Thank you! Now let's see how much I can get running properly by UPEW...
    James Michael Huselton said...
    edited 2009-06-10 03:10
    This sounds perfect!
    Thanks for supporting binaries.. It'll allow me to make a easy move from
    PropDOS to Largos without recompiling everything.
    Very nice..
    Edit: re-read your description.. Any chance of getting support for
    kickstarting "incompatible" binaries? [noparse]:)[/noparse]
    OBC
    New to the Propeller?
    Post Edited (Oldbitcollector) : 6/10/2009 4:32:01 AM GMT
    edited 2009-06-10 05:08
    They will run, but there may not be enough free cogs for all apps - currently the prototype needs at least two cogs to run in order to provide kernel and file system services.
    It should be noted that it will be very easy to configure Largos - just edit /etc/rc.local and /etc/modules smile.gif
    Give me a month or so and I'll have Largos down to one cog for minimal setups (ie just basic kernel + file system, possibly even bit-banged serial console in the same cog), then as long as a standard Spin app does not touch my SPI flash pins, it will run as-is. Until I have time to do an SD version of my file system Largos will require a Winbond 25X80 or compatible SPI flash for its root file system.
    Before anyone asks... Largos will never use any form of FAT for its root file system as it is not appropriate for a Unix like OS. I will however provide at the very least some commands to copy to/from FAT formatted SD cards - I am going to call them "mdir", "mcd", "mread" and "mwrite" - shades of old Linux utilities smile.gif and the Prop2 version will support mounting SD cards under /mnt as the Prop2 will have a 256KB of hub ram.
    Oldbitcollector said...
    Very nice..
    OBC
    Post Edited (Bill Henning) : 6/10/2009 5:24:34 AM GMT
  • RossHRossH Posts: 5,780
    edited 2009-06-10 05:42
    Bill,
    /etc/rc.local ? /etc/modules ?
    I don't think "Largos" is an appropriate name anymore - I vote for BILLIX! smile.gif
    Ross.
  • jazzedjazzed Posts: 11,803
    edited 2009-06-10 06:07
    Fascinating. nano-unix [noparse]:)[/noparse]· nanix maybe?
    How do you start a cog task without fork? clone maybe?
    Do you have room for KLMs and standard driver APIs (open,close,ioctl,read,write)?
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-06-10 17:33
    LOL!
    Here, laugh some more - here is the directory tree on my Winbond:
    /bin
    /dev
    /etc
    /etc/modules
    /etc/rc.local
    /lib
    /home
    /roms
    /usr
    /usr/bin
    /usr/man
    /usr/src
    /var
    /var/log
    /var/log/messages
    Does any of that look a teeny bit familiar? Ofcourse /etc/modules, /etc/rc.local, /var/log/messages are just text files, not directories.
    /roms is where full eeprom images get stored for ported eeprom games, femto basic once pin-adjusted, etc.
    RossH said...
    Bill,
    Ross.
    Post Edited (Bill Henning) : 6/10/2009 5:45:24 PM GMT
    edited 2009-06-10 17:35
    Hi
    spawn() - starts a new task in a new cog, LMM/Spin/otherVM based on args
    exec() - replaces the shell for BIG apps, can be used to do things like chaining multi pass compiers for example.
    Any newly started process can be used to extend the kernel, special sauce will be revealed later smile.gif
    jazzed said...
    Fascinating. nano-unix [noparse]:)[/noparse] nanix maybe?
    Post Edited (Bill Henning) : 6/10/2009 5:46:49 PM GMT
    edited 2009-06-10 19:44
    I like /proc ... but that wouldn't be on the flash. What about /mnt ?
    Common Bill, lettuce have the special sauce [noparse]:)[/noparse]
    --Steve
  • ImageCraftImageCraft Posts: 348
    edited 2009-06-10 20:14
    Have you documented the System ABI yet?
    edited 2009-06-10 20:41
    ImageCraft said...
    No, not yet... I won't have time until after the Expo. It's based on message passing, and actually C will be more efficient at sending the messages than Spin.
    You will like the fact that I support launching arbitrary different LMM kernel versions based on file type. I'm in the middle of finalizing the relocatable file format, I am leaning towards removing having separate code and data segments and just having one relocation chain.
    Post Edited (Bill Henning) : 6/10/2009 8:47:12 PM GMT
    edited 2009-06-10 20:47
    /mnt may have to wait for prop2 - I am VERY resource constrained here. I *may* be able to support /mnt for SD cards formatted with my file system, however that will require FS changes to support the different way SD is used. I am afraid everyone will have to wait for Prop2 for /mnt with different file systems - or at least long enough for me to run the kernel and Largos in XMM.
    I'm leaving the special sauce for later...
    jazzed said...
    Post Edited (Bill Henning) : 6/10/2009 8:52:28 PM GMT
    edited 2009-06-11 09:47
    Can't wait to get my hands on it.
    Now I just have to find one of those winbond chips in auz...
    edited 2009-06-11 13:08
    Worst case, you can order the Winbonds from Digikey - however pretty much any SPI flash that has 4KB erasable sectors should work.
    edited 2009-06-11 13:16
    Las is now generating the relocation file needed for the loader in OBJ mode!
    The relocation file not needed in IMAGE mode where it generates an absolute eeprom image, but it is definitely needed when generating LMM apps.
    I decided to use a simple text file format for the relocation information, each record is on its own line, encoded as: "%C%06X\n" - a single character 'L' or 'W' for LONG or SHORT destination followed by a six hex digit offset into the OBJ file, which implies that the largest supported LMM executable size is 16MB (for now).
    I was going to use a binary file, but decided that for debugging purposes, wasting a bit of disk space was well worth it for a human-readable relocation file.
    I am now in the process of squishing a bug with forward referencing... then a bit more LMM support and its ready for outside testing!
    Post Edited (Bill Henning) : 6/11/2009 1:22:15 PM GMT
    edited 2009-06-11 13:26
    I am considering making writing LMM assembly code more transparent.
    Would you guys like it if the assembler auto-magically did the translations for multi-long LMM equivalents for the following COG instructions:
    JMP #label
    CALL #label
    RET
    DJNZ reg,#label
    (maybe more later)
    It would get rid of having to remember to use FJUMP, FCALL, FRET, and would add a source level equivalent to DJNZ.
    I would even add a bit of automatic optimization - if the label was in range, then JMP and DJNZ would use add/sub pc,#offset instead of a long with the destination address.
    JMPRET makes no sense in the LMM context as CALL/RET will use a stack for return addresses
    edited 2009-06-11 14:49
    A single line syntax set of "standard" LMM features would be sweet. Part of the problem with implementing LMM today is trying to understand how to use FJUMP or FLOAD for example which require at least 2 longs. Once you know things it's easier, but new "adopters" may be quickly thrown by LMM in it's many current forms.
    --Steve
    edited 2009-06-11 17:23
    When I came up with LMM I defined a "standard" set of LMM instructions, however people ended up (for good reasons) adding all sorts of extensions.
    Las will standardize "core" LMM programming, however I believe that a lot of people will still extend the LMM kernel with features I did not add - my theory was "KISS".
    Las is practically usable right now, I am just finishing some tricky issues like forward referencing labels in long's declared in COG or FCACHE or LMM sections... they need to be fixed up differently depending of the mode of the code and the mode of the label when it is defined. After thats working, I'll add the automagic LMM support I discussed above.
    jazzed said...
    edited 2009-06-12 01:09
    Bill: I am following your development with immense interest. Keep up the good work.
    Yes, I think it would be great for LMM to automatically calculate the jmp/call/ret instructions.
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    edited 2009-06-12 01:30
    Hi Bill,
    I wasn't aware that there was a final "standard" set of LMM instructions. I was of course aware of your brilliant original proposal for LMM here, but the last post on that thread was in 2007. Is that what you're referring to? As far as I can see there are only about half a dozen LMM instructions defined there (next/call/ret/cache/etc). I know there's a lot of more recent information on LMM in various other forum threads, but finding all the relevent stuff with the braindead forum search function (or even using the Google plugin) is so difficult that I wouldn't really be surprised that something like a fully fleshed out LMM standard could exist without my knowing about it. I actually got a lot of my LMM information from the Propeller Wiki (here) which is much easier to use. However, it describes a couple of different LMM implementations, and it also seemed a bit out of date compared to current developments so I ended up mostly creating my own (which I acknowledge is not well documented, so you've at least prompted me to put my own house in order and get on with that little job!).
    However, the point of this post is that I'm just not sure there even should be such a thing as "standard" LMM. While writing Catalina I found the need to include a significant number of LMM primitives - far more than allowed for in the original proposals - to improve kernel support for a general purpose stack and frame based language. There were also several of the proposed LMM primitives (such as cache) that I just found too difficult to use effectively, and which wasted too much space in the kernel that I wanted to use for other things. Of course, before richard (Imagecraft) chimes in here, I'm aware that ICCPROP does use caching, and doesn't (as far as I know) add any new kernel primitves of its own, so my inability to use your original LMM propsal efficiently probably says more about my lack of compiler writing ability than it does about anything else - but this is beside the point I am trying to make, which is ....
    I don't think of LMM as a static thing with a defined set of primitives. Forget about caching - even having call/ret as primitives presupposes a particular overlying architecture (i.e. stack based). For me, LMM is a technique, not a solution - and having the ability to redefine LMM primitives in order to meet the needs of the job in hand is one of the great things about the original concept (kudos to you!) and also about the ability of the Prop to bring it off (kudos to Chip Gracey and the Parallax team!). I've just gone back to re-read at your original LMM proposal, and (without trying to detract from it at all), the reasons I departed from it are still valid. They were necessary to better accomodate my original design goals for Catalina - e.g. Catalina required better frame support, plus more new LMM primitives than were originally allowed for, plus more general purpose registers than were originally allowed for.
    I think your LMM assembler has to accomodate many variants of LMM. If you can make it so that your assembler allows you to define a particular machine architecture (typically, just a set of registers) plus a customizable set of LMM primitives then I think you will have a great solution.
    Ross.
    edited 2009-06-12 02:39
    @Cluso - thanks, I am going to do that... it will make it much easier on people starting out.
    @RossH - ah... slight misunderstanding, we are far more on the same page as you think.
    There was not supposed to be a "final standard" that defined THE LMM kernel that none may modify - that was not the idea.
    The idea was that there is supposed to be a "standard minimum subset" that everyone has to support - with everyone free to add extensions.
    I am a big believer in the KISS principle, so the initial proposal deliberately limited the new instructions in order to leave as much kernel cog space free as possible, specifically so people could do useful extensions (like direct support for stack frames with variables on the stack, direct floating point support etc). I know that FCACHE is something that requires a fair bit of chewing on to use effectively, but I will in the future write an app note or two on it.
    Now that my assembler is running (I still have some bugs to squash (forward referencing from a word embedded in a long in a cog section) before making a public pre-release of it) everyone will see how I will be using it.
    I am making my assembler be extremely generic, so that it will work well for any kind of LMM kernel!
    edited 2009-06-12 02:44
    @Bill,
    Ok - thanks. I though that perhaps there was a standard somewhere that I had missed.
    Keep up the good work!
    Ross.
    edited 2009-06-12 02:55
    I guess I inadvertently highlighted standard. A minimum subset is useful of course.
    The biggest problem I faced when learning the LMM primitives was "what the heck does that mean and why are there 2 longs after that statement".
    Simplifying the minimum primitives to "one line instructions" as Bill had in his post along with a full explanation of what the primitives mean would help new users tremendously.
    --Steve
    edited 2009-06-12 03:26
    jazzed said...
    Documentation will be forthcoming... but less will be needed once my assember is out - because I've decided to hide most of the differences.
    There will no longer be a need to know the difference between JMP / FJMP, CALL / FCALL, RET / FRET - the assembler will generate the correct code depending on the mode it is in when it encounters the line with the opcode in it.
    FCACHE stays, although I may rename it CACHE... and the block is now ended with ENDCACHE - the assembler computes (and places into the right place) the number of longs to load.
    It is delaying the assembler a few days, but I am making LMM be FAR more transparent and easier to use for everyone, so I believe the delay is worth it.
    Here is one of the future example programs that will come with Las:
                output   image
                 org      0
    $include startup.asm    ' the $20 byte header that runs cognews the code at $20
    $include lmmkernel      ' 512 long kernel, that starts up LMM code at $220
                mov    dira,#1
    again   xor      outa,#1
                movk  r0,#80000000   ' new pseudo-op, loads a 32 bit constant into any cog register
                add     r0,cnt
                waitcnt r0
                jmp     #again
               end
    movk will take the constant from the long following the CALL FMOVK, where FMOVK is a new kernel function.
    ofcourse the "output/org/two includes" could be replaced with a single "$include kimage.asm", and the end is optional
    $include kimage.asm
                mov    dira,#1
    again   xor      outa,#1
                add     r0,cnt
                waitcnt r0
                jmp     #again
    Is that simple enough for a stand-alonge eeprom image lmm program that blinks P0?
    Post Edited (Bill Henning) : 6/12/2009 3:36:24 AM GMT
