Translation of important part:
I have an array and I would pass it to a string to then be able to compare it with another string with the strcomp method
Can I make a sum of string in spin to create another string?
Do or how to I create a string from an array?
Thank you for your help!
This is not a good translation, but it should give you and idea.
@hooktxu: Take Mike Greens suggestion, it should solve your problem.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
Have a look at this thread (http://forums.parallax.com/showthread.php?p=812377). There is an object attached to a message towards the end of the thread that may do what you want.
JMH
