Suma de strings — Parallax Forums
Suma de strings
hooktxuhooktxu Posts: 33
edited 2009-06-09 22:18 in Propeller 1
Hola a todos, espero que me podais ayudar todos aquellos que no os moleste que escriba en espa
    edited 2009-06-09 14:53
    I think you are asking how to create a string from bits and pieces to compare to another string.
    Have a look at this thread (http://forums.parallax.com/showthread.php?p=812377). There is an object attached to a message towards the end of the thread that may do what you want.
    edited 2009-06-09 15:09
    Translation of important part:
    I have an array and I would pass it to a string to then be able to compare it with another string with the strcomp method
    Can I make a sum of string in spin to create another string?
    Do or how to I create a string from an array?
    Thank you for your help!
    This is not a good translation, but it should give you and idea.
    @hooktxu: Take Mike Greens suggestion, it should solve your problem.
    Toys are microcontroled.
    Robots are microcontroled.
    I am microcontroled.
  • Mike HuseltonMike Huselton Posts: 746
    JMH
