Fuzzy Logic?
I have read about this "Fuzzy Logic", and that the Propeller is capable of it, and that is useful, but that's about all I know about it. I read somewhere that it is like cold, warm, and hot, instead of just hot and cold.
Can someone explain this to me, a 1 and 0 minded programmer? ProcessingData...
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
Visit the home of pPropQL, pPropQL020 and OMU for the pPropQL/020 at omnibus.uni-freiburg.de/~rp92
It is free for a 30 day trial download. Contact Hanno at MyDancebot.com.
JMH
Yes, Fuzzy Logic is integrated into ViewPort.
It provides a complete, high speed fuzzy logic engine to help you control all sorts of things. I use it to balance my DanceBot. The demo tutorial shows you how to "land on the moon" with fuzzy logic. Others have used it to optimally charge batteries and more. ViewPort provides you with a nice user interface to help you understand fuzzy logic. Want me to put together a video?
Hanno
Download a free trial of ViewPort- the premier visual debugger for the Propeller
Includes full debugger, simulated instruments, fuzzy logic, and OpenCV for computer vision. Now a Parallax Product!
define the fuzzy logic controller using python syntax (no real python knowledge is required other than basic syntax)
then run the code to generate either SPIN, RobotC, even assembly should be possible, but I didn't implement that yet.
This produces very tight, customized code for the particular fuzzy controller. I found this to be a little more efficient than a generic fuzzy library approach that recalculates the input and output set shapes every time.
Maybe if you have alot of different fuzzy logic controllers, a more centralized approach would be better.
I successfully used it in several robot applications, but it hasn't been widely tested other than by me.
There's also a visualization tool I wrote for it, but it basically just shows what the input sets look like.
One thing I think is cool, is the Python code used to "write" the fuzzy logic controller can be run to implement the controller on the PC (or embedded system running Python)
If anyone's interested, I could dig it out of the archives and post it.
Very interesting.
If You can post it
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
http://forums.parallax.com/forums/default.aspx?f=25&m=357686
and here for the video:
Hanno
START:·
>Saving Data. . . .
>Signing OFF
for just reading a analog voltages you don't need fuzzy logic at all.
You can use the ADC-object from the obex. Or any kind of ADC-chip you like combined with supernormal-programming.
Fuzzy-logic is for controlling devices with a behaviour that has a lot of parameters that influence each other crossover again and again
and where it is impossible to program mathematical exact rules what the program should do in different situations. Here fuzzy logic can help you
"find the way out the labyrinth"
analog-to-digital-conversion is very easy to catch in exact "mathematical" rules
just use the ADC-object from the obex and don't care about the details how it is done
or use an external ADC-Chip with a digital interface
by the way this is another great example how different solutions can be offered as soon as
details are given what should be done in the end
I think just reading analog voltages is NOT the end of your project
Post what you want to do ALL in THE END
and I bet the forum members will find much better solutions than fuzzy logic
best regards
Stefan
Sometimes there is just one input and one output. Like "What is the temperature of the water" and "How much current should go to the heater"
The real beauty of fuzzy logic is that even when you can figure out a mathematical model of a system...you really don't need to in order to control it effectively.
Rather fuzzy logic allows the designer to use common sense rules like "IF the water is too hot THEN turn the heat down".
A handful of rules like this is all that is needed...well you also need to define what HOT, COLD, UP, DOWN, etc. mean, but that's not normally very hard.
I like to use fuzzy logic instead of PID controllers...but other people prefer the PID method.
StefanL38 is right, there are often many different paths that lead to the same goal. Sometimes Fuzzy Logic will be the right path and sometimes it will be more of a hurdle than a help.
I'm not really trying to do a project.
I was talking about the mystery of Fuzzy with my dad one night, and found out he knew about it, sort of. So I thought that I would try to find out if the prop could do it, and what it was. So, after reading through the propeller manual, finding it said something about fuzzy, I went to my dad's old "Microproccessers and Interfacing" book for the 8086/8088 Proccesser. After reading a short, technical and unhelpful paragraph, I thought "Why not try the forums?"
I'm just trying to find out as much as I can, Assembly, SPIN, Fuzzy logic, controlling servos, ect. I want to have most of the info and knowledge I can get before I try for a project.
Thanks again for your help. - ProccessingData
START:·
>Saving Data. . . .
>Signing OFF
so if your forum-name is your philosophy go on "processing data" by reading.
I want to make a suggestion: how about trying a new way of learning be realizing a program ?
Choose whatever you like, but start DOING it before knowing it all. If you go on just reading for weeks or even longer
you will forget most of it. Things that you have USED while programming will stay in mind.
So start processing debug-data in a propeller-program !
best regards
Stefan
