A 3.3v leg broke off my prop. — Parallax Forums
Clock LoopClock Loop Posts: 2,069
edited 2009-06-07 22:15 in Propeller 1
It actually still works.
So far I am not using all I/O's and I don't draw any current from them at all. Just data, and signal.
Anyone know what this would do to the stability of the chip? I don't plan to use this one farther than debugging/proto but I was just curious.
Post Edited (BPM) : 6/6/2009 6:17:32 PM GMT
oops.jpg 813.8K
    edited 2009-06-06 18:04
    If there's any metal still visible, you might be able to solder a thin wire to it. ???
    Oops, I thought you had a DIP chip, just noticed it isn't - sorry.
  • hover1hover1 Posts: 1,929
    edited 2009-06-06 18:10
    BPM said...
    There are 4 VDD connections on that package. Pins 8,18,30 and 40. I just don't know if they are connected together internally.
    And you· meant 3.3V leg, right?
    Wouldn't a breakout board be in order before you lose an important pin?
    Jim
    Post Edited (hover1) : 6/6/2009 6:19:23 PM GMT
    edited 2009-06-06 18:17
    hover1 said...
    And you meant 3.3V leg, right?
    Jim
    Lol, yea... It still acts like nothing happened... I love this chip... (before its leg broke too)
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-06-06 18:27
    hover1, all VDD pins are all connected internally, although they are interconnected with VERY fine conductors. The same applies to the VSS pins.
    The external power pins can be seen as connecting the outside power source, to the internal supply(inside the chip), through some resistors. Each pin has it's own resistor, but they all tie back to the same point within the chip. Sort of.
    edited 2009-06-06 18:34
    Philldapill said...
    Thanks Phil,
    I thought that was the case.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-06-06 18:53
    As Monty Python's Black Knight says: " Eets only a flesh wound! "
    I also had to laugh when seeing all the wire's soldered right to the pins --- almost a work of art in its own right!
    - H
    No matter how much you push the envelope, it'll still be stationery.
  • Matthew BurmeisterMatthew Burmeister Posts: 49
    edited 2009-06-06 19:01
    CounterRotatingProps said...
    - H
    Same here lol
    edited 2009-06-06 19:36
    There are many organisations around the world dedicated to the prevention of crualty to xxxxx. Is nobody going to help save that poor propeller?
    How long did it take for one leg to fall off? There doesn't seem to be anything in the datasheet about the absolute max number of pin waggles.
    Careful carving with a fine blade may allow a wire to be stuck on but I doubt if it would stay stuck for long, the solder would be too soft smilewinkgrin.gif
    edited 2009-06-06 19:43
    Toby, you know, I thought the picture showed the poor little Prop breaking out in a sweat... maybe I was wrong, and it means something else:
    BPM, you've not also been water-boarding your Prop, have you?
    edited 2009-06-06 20:11
    Place the Prop in a petri dish full of nutrient, and put it in a warm dark closet for about a week. The leg will grow back on its own.
    If that fails for some odd reason, put it under your pillow at night. With luck, when you awaken, you'll find some money in its place to buy another one.
    edited 2009-06-06 20:19
    Indeed, Phil,
    I too have recently learned to believe in the Prop Tooth Fairy [noparse]:)[/noparse]
    - Howard
    edited 2009-06-06 20:31
    i have soldered chips like this in the past. you should get some 0402 0.1uF caps to solder across the vss and vdd pins. Just for the great laugh you gave me I will send you a 1x1 free or several pcb free if you pay the postage. They are qfn though not qfp
    propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-06-06 20:42
    It is a· cry.gif·ing Shame what you did to that Prop's Poor Legs and what happen to the one that broke off
    smile.gif·That it still works
    But in all fair-nest This look like something that·I would do if I did not have the socket for it
    It dose look funny to see it wired up that way..........yeah.gif........hop.gif
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    Post Edited (sam_sam_sam) : 6/6/2009 8:51:27 PM GMT
    Yea, my first prop will go into a display case when its officially toast. Not yet tho.
    Its a hack soldering job, but I have less than ideal conditions to work in,
    and no microscope to help me see.
    I can manage without, but need, and have, a fine tipped precise temp soldering station.
    Without a nice soldering gun, this would be impossible.
    Water-boarding? Who me? Pfft.. who cares anyhow, we all love to get waterboarded, i mean after all, its not like its torture or anything .... I know my chips love the water, and me, I can't get enough of it, and that new sport them crazy government people keep talking about, what was it,,, oh yes, water breathing. I love to inhale water, its so fun, everyone should do it. "please do not try this at home"
    Mabee its an attempt to out do fire breathers?
    The chip looks wet because it was taken with a 10 megapixel camera in "macrovision" mode.
    I also lit the chip with a red and blue led.
    Meh. Nothing here, move along.
    edited 2009-06-06 20:48
    JBC makes the best soldering irons. I have an AD2700 and love it. Heats instantly and can change tips while still hot. a must for those who can not afford multiple irons. And the tips last what seems forever. I have had it for years and have not changed tips yet.
    edited 2009-06-06 22:03
    Speaking of soldering irons; how much does one like that cost?
    @BPM: Your poor Propeller!! smile.gif
    Toys are microcontroled.
    Robots are microcontroled.
    I am microcontroled.
    edited 2009-06-06 22:05
    BPM said...
    Ok,
    I actually·held my tounge on the first reply, but after all the other posts.....what the .....?
    I would have at least hot glued the prop to a 2x4 to minimize some of the physical abuse.tongue.gif
    We all do what we have to do. Glad it's still workin'
    Jim
    edited 2009-06-06 22:08
    The JBC AD 2700 has been discontinued. The AD 2950 kit(cotroler, 50W hand piece, and tip) is $375. Not cheap but neither are there competitors and the competitors tips do not last as long, or as versitile or heat as quickly. Note never use a sponge to clean your tip. use plated steal woll
    http://www.howardelectronics.com/jbc/ad2950.html
    edited 2009-06-06 22:28
    hover1 said...
    I would have at least hot glued the prop to a 2x4 to minimize some of the physical abuse. tongue.gif
    Jim
    Actually, when deadbugging, I like to let many wires just hold it in place.
    Usually it works well, this time I messed up by making that 3.3 line too short, it was the first line i ran.
    I never realized it was getting stressed, apparently it was, and after looking at the wire, it was too short.
    1280 x 960 - 813K
    edited 2009-06-06 22:31
    mctrivia said...
    Note never use a sponge to clean your tip. use plated steal wool
    i like to use those pots and pan steel scrubbers to clean my tips, but they aren't steel, they are aluminium or something.
    edited 2009-06-06 22:34
    what I use is not steal either. it is gold plated copper. sill looks like steal wool and I am sure he regular ones as long as they do not have soap built in would be just as good.
    edited 2009-06-06 22:40
    mctrivia said...
    Cmon chips need soap too, it would go well with the waterboarding.
    edited 2009-06-06 23:33
    Righto! OK --- who's gonna invent the First Propeller-Powered Shower ?
    > AD 2700 has been discontinued ... AD 2950
    mctrivia, the tips are the same though, right? Do you do any lead-free soldering with this? That sites got a couple of good soldering videos too.
    - H
    edited 2009-06-06 23:50
    Yes my new propmod are completely lead free and the iron has no trouble. The tips between the two models are the same. They come in all kinds of shapes and sizes. For myself I have a realy sharp one 2245-003(I bought 3 with the iron since when I used wellers I had to replace tips weekly. Still have 2 unopened years later). and a big fat one for heavy traces and header pins.
    The weller tips are much cheaper then JBC because the heating element is in the tip on the JBC. This is why they can heat up so quickly and why with the stand is easy to change tips while still hot.
    edited 2009-06-07 19:29
    Here is a model that I use and works very well and for a lot less money
    http://www.howardelectronics.com/xytronic/169D.html
    Sam
    edited 2009-06-07 20:51
    Well..... The soldering iron I am using right now cost about $20, and I have to replace tips about once every 3 small solder jobs. So I never have used a "good" soldering iron; and I finaly replaced the tip on my iron (it was originaly a point; now it's flat) and if I ever got the opertunity I would buy a nice one with a sharp tip that might even be SMD worthy. smile.gif
    edited 2009-06-07 21:05
    Not here too, there is alreadt a shower related prop project being discussed.
    To put a prop on the rack is one thing, but to do it with art direction and lighting is bordering on vindictive!
    (said by somebody that reversed the power to one defenseless lil' prop)
  • LeonLeon Posts: 7,620
    edited 2009-06-07 21:19
    I've used Metcal equipment for years - the second-hand STSS power unit with the newer MX-500 handpiece and cartridges cost about the same as a new Weller. The cartridges last a very long time if they aren't mistreated.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-06-07 21:29
    Thanks for posting that Leon,
    I'm shopping around for new irons - do you buy them from any particular vendor?
    A side note: "G1HSM" - you must have been HAMming it up for many years, to have received such a terse sign, eh?
    - Howard
    edited 2009-06-07 21:37
    The STSS power units often come up on Ebay, as well as new cartridges. The equivalent current model is the MX-5000.
    I've had my license since 1984.
    Leon
