A 3.3v leg broke off my prop.
Clock Loop
It actually still works.
So far I am not using all I/O's and I don't draw any current from them at all. Just data, and signal.
Anyone know what this would do to the stability of the chip? I don't plan to use this one farther than debugging/proto but I was just curious.
Post Edited (BPM) : 6/6/2009 6:17:32 PM GMT
Oops, I thought you had a DIP chip, just noticed it isn't - sorry.
And you· meant 3.3V leg, right?
Wouldn't a breakout board be in order before you lose an important pin?
Jim
Post Edited (hover1) : 6/6/2009 6:19:23 PM GMT
Lol, yea... It still acts like nothing happened... I love this chip... (before its leg broke too)
The external power pins can be seen as connecting the outside power source, to the internal supply(inside the chip), through some resistors. Each pin has it's own resistor, but they all tie back to the same point within the chip. Sort of.
I thought that was the case.
As Monty Python's Black Knight says: " Eets only a flesh wound! "
I also had to laugh when seeing all the wire's soldered right to the pins --- almost a work of art in its own right!
- H
No matter how much you push the envelope, it'll still be stationery.
Same here lol
How long did it take for one leg to fall off? There doesn't seem to be anything in the datasheet about the absolute max number of pin waggles.
Careful carving with a fine blade may allow a wire to be stuck on but I doubt if it would stay stuck for long, the solder would be too soft
Toby, you know, I thought the picture showed the poor little Prop breaking out in a sweat... maybe I was wrong, and it means something else:
BPM, you've not also been water-boarding your Prop, have you?
If that fails for some odd reason, put it under your pillow at night. With luck, when you awaken, you'll find some money in its place to buy another one.
I too have recently learned to believe in the Prop Tooth Fairy [noparse]:)[/noparse]
- Howard
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
But in all fair-nest This look like something that·I would do if I did not have the socket for it
It dose look funny to see it wired up that way..........
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 6/6/2009 8:51:27 PM GMT
Its a hack soldering job, but I have less than ideal conditions to work in,
and no microscope to help me see.
I can manage without, but need, and have, a fine tipped precise temp soldering station.
Without a nice soldering gun, this would be impossible.
Water-boarding? Who me? Pfft.. who cares anyhow, we all love to get waterboarded, i mean after all, its not like its torture or anything .... I know my chips love the water, and me, I can't get enough of it, and that new sport them crazy government people keep talking about, what was it,,, oh yes, water breathing. I love to inhale water, its so fun, everyone should do it. "please do not try this at home"
Mabee its an attempt to out do fire breathers?
The chip looks wet because it was taken with a 10 megapixel camera in "macrovision" mode.
I also lit the chip with a red and blue led.
Meh. Nothing here, move along.
@BPM: Your poor Propeller!!
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
I actually·held my tounge on the first reply, but after all the other posts.....what the .....?
I would have at least hot glued the prop to a 2x4 to minimize some of the physical abuse.
We all do what we have to do. Glad it's still workin'
Jim
http://www.howardelectronics.com/jbc/ad2950.html
Actually, when deadbugging, I like to let many wires just hold it in place.
Usually it works well, this time I messed up by making that 3.3 line too short, it was the first line i ran.
I never realized it was getting stressed, apparently it was, and after looking at the wire, it was too short.
i like to use those pots and pan steel scrubbers to clean my tips, but they aren't steel, they are aluminium or something.
Cmon chips need soap too, it would go well with the waterboarding.
Righto! OK --- who's gonna invent the First Propeller-Powered Shower ?
> AD 2700 has been discontinued ... AD 2950
mctrivia, the tips are the same though, right? Do you do any lead-free soldering with this? That sites got a couple of good soldering videos too.
- H
The weller tips are much cheaper then JBC because the heating element is in the tip on the JBC. This is why they can heat up so quickly and why with the stand is easy to change tips while still hot.
http://www.howardelectronics.com/xytronic/169D.html
··Thanks for any·
Sam
To put a prop on the rack is one thing, but to do it with art direction and lighting is bordering on vindictive!
(said by somebody that reversed the power to one defenseless lil' prop)
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I'm shopping around for new irons - do you buy them from any particular vendor?
A side note: "G1HSM" - you must have been HAMming it up for many years, to have received such a terse sign, eh?
- Howard
I've had my license since 1984.
Leon
