Propeller System Module: In Production!
The first unit has just rolled off the assembly line and appears to work perfectly!
I'll start selling them soon.
I've put up a web page for it here:
http://www.rayslogic.com/Propeller/Products/Products.htm
Here's what it looks like (I've added a called out layout):
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Post Edited (Rayman) : 6/4/2009 9:41:16 PM GMT
How much?
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Bean: The schematic is not currently in presentable format! I'll work on that though...
Largos - a nano operating system for the Propeller
www.mikronauts.com - a new blog about microcontrollers
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Not the fish.
sites.google.com/site/bitwinproject/
The graphical driver does things like lines, circles, bitmaps, text, etc., on a pixel addressible basis in 18-bit color.· This is the driver used by the serial command interface app that the PSM will be pre-programmed with.
The tile driver is as easy to use as TV.SPIN or VGA.SPIN.· The display basically pretends to be either a TV or a VGA monitor.· I've even run the "Graphics_Demo" with just a couple changes.· I will include something like TV_Text.SPIN to make it even easier...
- Howard
No matter how much you push the envelope, it'll still be stationery.
Really nice. You've certainly packed a lot on there.
Can I ask what the width of the board is?
tubular
edit: It would be a bargain at that price too. Similar (non Prop) boards are several hundred and only diff is touch screen and maybe ethernet
Post Edited (Tubular) : 6/4/2009 11:32:34 PM GMT
The board is the same as required for ExpressPCB's $61 miniboard service.· I'm going to provide a layout with the headers so people can make their own accessory boards if they want.· I'm doing my own accessory board right now that will provide rechargeable battery power, RCA video jack, keyboard jack, mouse jack, real time clock, and (hopefully) a servo header (we'll see if I can provide enough current).· It will just attach to the back of the PSM with 10-pin, 3-pin, and 4-pin headers...· Of course, this uses up most of the free pins...
That price may just have to be an introductory price.· I'll have to add something later for distribution costs...· I'm also planning on selling a few even cheaper at the West Coast expo!
Nice!
I also went to your site and found the RPN Calculator! Very cool...
Whit+
JMH
Post Edited (James Michael Huselton) : 6/5/2009 1:11:19 AM GMT
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
How hard would it be to add or change to a touch screen version?
Even if it can't I will prob have to get these instead of Tube's PropPLC
BH
P.S. Will the accelerometer work if the rig is in a vertical position?
Post Edited (BADHABIT) : 6/5/2009 5:32:09 AM GMT
humanoido
The accelerometer works in any orientation. The part# is MMA7260QT.· Here's the datasheet:
http://www.freescale.com/files/sensors/doc/data_sheet/MMA7260QT.pdf
Ut oh, competition is heating up and its still three weeks to UPEW
I suspect there will be a flurry of great designs coming out. It may well be the best ever time to buy prop stuff...
tubular
My boss once said "I pay him to do his bobby". He knows me too well
Visit the home of pPropQL, pPropQL020 and OMU for the pPropQL/020 at omnibus.uni-freiburg.de/~rp92
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
I think that you should put an accelerometer socket on the touchscreen version so those who needed it could buy it and put it in themselfs.
Seems like a good idea to put some epoxy on the LCD connector to make it look better and hold it in place.· I need to work on the "make it look better" part though, the epoxy was a little less viscous than I thought...
Question: what size EEPROM on board for Prop?
Jim
Also, the accelerometer can be used to give a kind of mouse input.· You can move a cursor just by tilting the display one way or another...· That and the pushbutton can let you create a UI that doesn't require a touchscreen or a mouse...
Post Edited (Rayman) : 6/6/2009 1:57:08 AM GMT
I wanted to know if there was any EEPROM on board since it was not mentioned in any specs. Yes, SD is fine for logging. I use a 2GB uSD on a Proto Board with Tim's 3" NTSC LCD for GPS logging right now, and it works well in·most of·my situations, but it is too fat ( ie deep) for a current project. Your single board solution looks like a good fit.
In·my current project, the display will be mounted·in a dash. I don't think I can hold the board·in one hand while driving·a hovervcraft at 50 MPH on water·
When will they be ready to ship? Can I have one yesterday?·
Jim
Post Edited (hover1) : 6/6/2009 3:07:16 AM GMT
