Can the Prop run from a coin cell?
Tubular
Has anyone successfully run the prop from a 3v coin cell (CR2032, CR2430 etc)? I'm worried about getting past the initial boot phase, after that the clock can be slowed.
I'm interested for two reasons - 1) an ultra portable design and 2) revisiting PhiPi's suggestion of programming (and possible energy harvesting) via an audio interface (iPod, cell phone here we come)
tubular
tubular
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
The main problem I see with running off a coin cell is that the nominal voltage supplied is already below the normal operating voltage of the Propeller. If you add a diode or even a saturated transistor's voltage drop, you're well below 3V. You'd need the diode or transistor to switch over between the coin cell and whatever other power source you're using. It might be better to use a buck/boost regulator to supply 3.3V from whatever source is available. That would allow for input voltages from 2.7V or lower to 5V or higher.
You can do switch over with lower drop by using mosfet. If you really don't want a power supply.
Also, button cells tend to be pretty good about supplying high current when it's needed. They can get hot enough to start a fire if you short the out in the presence of something that burns.
@mike the datasheet indicates 2-2.4mA during boot. The sanyo datasheet doesn't tell me a lot about the internal resistance when pulling a few mA, though for a CR2430 it does indicate 6mA continuous can be drawn (I'll have to experiment to see how far it dips down under load)
@mctriv, the boost may be a good option. This design calls for minimal components so I'm going to try without it initially and see what can be done. If need be I'll grab a couple of your modules.
@localroger, thanks that info makes it worth a shot. Perhaps once the prop has used up the available higher voltage juice I can use the remainder to smoke a resistor, mission impossible style.
tubular
edit: @FearTurtles, you're right, 2.7 volts. Not a lot of margin for dips down that low, but then again I'm not switching any significant load
Post Edited (Tubular) : 6/3/2009 3:14:01 AM GMT
Estimate using 27mm battery
I'll do some run-down tests and post the results running various applications...
tubular
I wish that the prop had been designed for Li-ion voltage spreads of 4.2 - 3.7 Volts. This would allow battery useage without all the regulators with their evils.
With the overdesign that has gone into the prop, I wouldn't be surprised if it worked just fine at 4.2 volts, but try it out at your own risk ;^)
On the otherhand, if it was designed to accept a wider range of operating voltages, wouldn't it just have a buck/boost built in, and therefore just loose the efficiency all of the time.
McTrivia: Isn't the buck/boost regulator in the 90% range of efficiency?
focus.ti.com/lit/ds/symlink/tps63001.pdf
The trouble is that a lot of the stuff I want to use batteries for are sig generators which need to give known levels, so a regulator is still needed. It just grates with me to use two Li cels giving 8.4 volts to only blow it down to 3.3 V, even if the cells are 2 AH and free. I suposse I should just accept it, after all 5 Volt batteries were a bit rare too.
There are some very low dropout regs, about 0.2 volts under load, which will happily regulate a 3.7v LiPo. Check out the LP3874 for instance. I'm sure there are others
tubular
Many of the LDO regs I have been tempted by in the past do give regulation but their own quiecent current shoots up at that point. With 2AH cells I suppose it wouldnt matter too much but then I get all pious about energy usage and want it to run for lots of hours without recharges.
I should stop thinking of everything, and do something
