pre-UPEW 2009 announcement: H49S 6.25MHz crystals - runs Propeller at 100Mhz
Bill Henning
Hi,
Since the 6.25MHz thread has been active, I thought I should announce one of my upcoming products that I was going to announce at UPEW 2009.
I really liked the idea of running my Propellers at 100MHz, so I have placed a large order for custom manufactured 6.25Mhz crystals. I will be selling them through my web store (which is in the process of being set up) - the prices will be reasonable, just a bit higher than 5MHz crystals at the Parallax store. I will be able supply as few or as many as you may need.
Best Regards,
Bill
Largos - a nano operating system for the Propeller
www.mikronauts.com - a new blog about microcontrollers
Post Edited (Bill Henning) : 6/1/2009 6:28:00 PM GMT
Best Regards,
Bill
I would like to hear from Chip about his thoughts for 100MHz operation.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Actually, hobbyists applications are where I wouldn't use it. To many people would be tripped up by the need to change the crystal frequency in the codes...
Besides, in the Parallax boards, the crystal just pops out.· One could just copy that hardware to make the crystal changeable.
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
A couple of years ago, before the data sheet, Chip posted that Propeller chips are tested at room temperature at 104MHz (6.5MHz * 16) - see http://forums.parallax.com/showthread.php?p=620404.
The Propeller data sheet (v1.2) has a "Fastest Frequency vs. Temperature chart " that indicates that Propellers will run at 100MHz in with the ambient temperature being as high as 75'C - which is the top end of the normal "commercial temperature range".
Would I run "life support" equipment on a 100MHz Prop? No, but neither would I on an 80MHz prop, without extensive testing... which could also be used to "qualify" 100MHz parts.
Based on the data sheets, not to mention people's successes running even faster, I think 100MHz is a great clock speed
Leon
Post Edited (Leon) : 6/1/2009 2:04:33 PM GMT
The "AC Characteristics" in the data sheet show that they are for the milspec temperature range of -55'C to +125'C, however the "Fastest Frequency vs. Temperature chart " shows that it will operate at 100MHz at up to +75'C.
A few years ago I designed a small microcontroller based remote I/O node that had to run at 125'C, and it worked well, however the vast majority of applications run well below even 75'C.
Leon
Post Edited (Leon) : 6/1/2009 3:33:31 PM GMT
1986 Chevy EL Camino·· No prop yet
1984 Suzukie GS1100GK No prop yet
Just in time I run 2 Propellers with 15MHz PLLx8 in my tests.
One on Clusos Triblade (Blade1) and one on ProtoBoard with USB in one month and not any heat from Propeler at al.
It runs very stable. But it is important to have last one 4,7-10 uF capacitor near Propeler on crystal side and parallel with one smal ceramic capasitor.
Smal capacitor is for block high frequensies to and from Propeler and 4,7-10 uF is for Voltage stablity with times Propeller consume momentary more power.
Most heat Propeller produce with not stable square wave on its crystal driver.
And PLLx8 wil (one divider stage) recondition square wave on driver for rest of Propeller logic.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
That's great! Wow... 120MHz... I'll have to try that.
It really shows what a great job Parallax did on the Propeller - no wonder the chart shows that the Propeller will run at up to 100MHz at 75'C.
Hmm... I wonder what the Propeller could do if one stuck a big peltier element on it (and ofcourse a BIG heatsink/fan on the peltier) and ran it at 5V...
Best Regards,
Bill
OBC
New to the Propeller?
Maybe at You Pee Ewe a table could be set up to experiment with OC. 80 mhz hah!
Regarding Bill's question, Chip says "It would probably work just fine - I think we tested at a bit above 100 MHz".
Nothing wrong with experimentation, and I'm not concerned about RMAs or the fact that it's out of specification from the datasheet. Our customers have produced lots of valuable information about our products, such as Tracy Allen's BASIC Stamp characterizations. You guys have fun.
We could offer those for sale from our web site, Bill. Contact me offline kgracey@parallax.com with some pricing information. Sounds like a nice hotrod upgrade.
Has the Propeller actually been characterized for 100 MHz operation and for a crystal > 8 MHz with the PLL? I've been taken to task for suggesting that running it outside the specification parameters is a bad idea, although it might be acceptable for a hobbyist application.
Leon
Post Edited (Leon) : 6/2/2009 8:16:27 AM GMT
Leon
Post Edited (Leon) : 6/2/2009 2:43:09 PM GMT
Design rules for stable propeller operation and overclocking
http://forums.parallax.com/forums/default.aspx?f=25&m=356308
For non-commercial, 100MHz here we come...
Post Edited (SRLM) : 6/2/2009 8:14:07 PM GMT
I should be receiving the first shipment around June 15th
