Random Numbers Between 0 and n-1
Phil Pilgrim (PhiPi)
I was doing some AVR programming and need a quick, short random number generator that produced values between zero and a limit - 1. The usual way to do this is to generate a full-sized random number, divide it by the limit, and use the remainder. But this was too complicated, and I didn't have room for a division routine anyway. So I started to think about how LFSRs are written, and it dawned on me that each step in the LFSR could produce one bit of a number that I could use to multiply the limit by to produce a fractional product (i.e. the product's upper bits). From there it became just a matter of inserting a conditional add and a shift into the LFSR routine.
So I wrote a version for the Propeller, based on Chip's LFSR in the Spin byte code interpreter. It required two additional instructions:
To give it a quick test, I ran the above code and plotted each output value against the one following it in a scatter chart to see if there were any obvious correlations. There don't seem to be any, but more rigorous tests would not be inappropriate:
This method suffers the same shortcoming that the remainder method does, though: it maps a domain of 232 - 1 values into a range of n values. If n doesn't evenly divide the domain size, the relative frequency of some result values will be higher than others by one.
[b]CON[/b]
[b]_clkmode[/b] = [b]xtal1[/b] + [b]pll16x[/b]
[b]_xinfreq[/b] = 5_000_000
[b]VAR[/b]
[b]long[/b] arg[noparse][[/noparse]*2]
[b]OBJ[/b]
sio : "FullDuplexSerial"
[b]PUB[/b] Start
sio.start(31, 30, 0, 9600)
[b]cognew[/b](@random, @arg)
[b]repeat[/b] 1000
sio.dec(limit_rand(100_000))
sio.tx(13)
[b]PUB[/b] limit_rand(limit)
'Return a uniformly-distributed random number between 0 and limit - 1.
arg := limit
[b]repeat[/b] [b]while[/b] arg
[b]return[/b] arg[noparse][[/noparse]*1]
[b]DAT[/b]
[b]org[/b] 0
random [b]mov[/b] xaddr,[b]par[/b] 'Get address of input value.
[b]mov[/b] yaddr,[b]par[/b] 'Get address of output value.
[b]add[/b] yaddr,#4
:waitarg [b]rdlong[/b] x,xaddr [b]wz[/b] 'Is input value non-zero?
[b]if_z[/b] [b]jmp[/b] #:waitarg ' No: Try again.
[b]mov[/b] y,#0 'Initialize result.
[b]mov[/b] bitcnt,#32 'Initialize bit count.
:randlp [b]test[/b] rand,#%10111 [b]wc[/b] 'LFSR: Get parity of tap values.
[b]rcr[/b] rand,#1 'Shift odd parity in though top.
[b]if_c[/b] [b]add[/b] y,x [b]wc[/b] 'Add input to product if carry (like multiply). ***
[b]rcr[/b] y,#1 'Shift carry into result from top. ***
[b]djnz[/b] bitcnt,#:randlp 'Back for another bit.
[b]wrlong[/b] y,yaddr 'Save result in hub.
[b]mov[/b] x,#0 'Zero input.
[b]wrlong[/b] x,xaddr 'Save zero in hub to signal done.
[b]jmp[/b] #:waitarg 'Dum de dum...
rand [b]long[/b] $1234_5678 'Random seed.
xaddr [b]res[/b] 1 'Hub address of input.
yaddr [b]res[/b] 1 'Hub address of result.
x [b]res[/b] 1 'Input value.
y [b]res[/b] 1 'Result value.
bitcnt [b]res[/b] 1 'Bit counter.
'*** These two statements added to regular LFSR for limiting.
I really like the code you created. I'm trying to create a game that requires an array filled with random integers, so your limit_rand method works perfectly. However, i was trying to make it so that the seed value changed so the game wouldn't have the same array of "random" integers by setting the seed value: rand long, to CNT, but this doesn't seem to be working. Here is part of my code:
PUB simonGame Listen.start(31, 30, 0, 9600) waitcnt(cnt + 1440000000) cognew(@random, @arg) Listen.dec(cnt) repeat 30 Listen.dec(limitRand(10)) Listen.tx(13)Listen is an object of FullDuplexSerial. I also have the line:
in the DAT block.
Suggestions?
Also, I'm fairly new to spin. What is the OBEX and how can i implement an object of the RealRandom class?
See the manual under OBJ for general info and Chip's RealRandom object for implementation specifics.
http://www.codeproject.com/KB/recipes/SimpleRNG.aspx
0 to (2^32)-1 can just map into 0 to (1-1/(2^32))
Yes, it would, so long as speed was not a factor. The thrust of my effort was providing the quickest possible 0..n-1 pseudorandom generator.
