SD and microSD compatible?
Hello All,
I've been using the SDCard adapter from ucontroller.com very happily (http://ucontroller.com/documentation/SDCardDoc.html)
I'm working on a project that will need several boards made, I'm not ready to jump into surface mount soldering so I was thinking about just putting one of these directly to the board.
Is microSD the same as SD only smaller?
would this product (with several pin swaps) work the same way? (http://www.sparkfun.com/commerce/product_info.php?products_id=544)
Its much smaller and would make it easier to put onto a board I was making.
I'm using the fsrw & friends routines for the SD Filesystem.
Rick
Rick
SDcard is also capable of using 4 bit parallel transfers to speed things up. MicroSD is not. I don't even think there is a 2bit parallel mode for MicroSD.
On the propeller, I don't believe anybody has implemented any 4bit protocol as of yet, so I would go with microSD. I have a previous version of that breakout board with some 10K pullup resistors. It works great.
It was a little confusing because of the difference in nomenclature, but it works great on my Demoboard.
Visit the home of pPropQL, pPropQL020 and OMU for the pPropQL/020 at omnibus.uni-freiburg.de/~rp92
I'll give it a shot with the micro.
Rick
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
propmod_us are now in stock. propmod_1x1 arrive on 26th. Only $30
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
