Broadcast video to be used as a wireless comm. link? — Parallax Forums
PhilldapillPhilldapill Posts: 1,283
edited 2009-06-01 15:14 in Propeller 1
If I understand the Propeller's video hardware correctly, it has the ability to transmit low quality video over the air for a short distance. Is this correct?
If this is indeed correct, can't this be exploited, with a few external components, to transmit data over a short range? Heck, 5 feet would be terrific!
So, is this at all possible? If so, has it been worked on?
  • heaterheater Posts: 3,370
    edited 2009-05-29 06:31
    Do we need to use the video hardware? The counters can generate some nice R.F. simply enough.
    On the receiving end there is already a published quadrature demodulator/spectrum analyser.
    Looks like frequency modulation might be the way to go.
    What would be a good carrier frequency?
    What about all those spurious harmonics from the transmitter.
    Do we need a couple of transistors for an R.F. amplifier on the receiver?
  • ericballericball Posts: 774
    edited 2009-05-29 13:19
    Broadcast is mostly amplitude modulated baseband (ignoring the aural bit).· I remember seeing a post where Chip(?) described the actual process but I haven't been able to find it.· Baseband is 3 bit PCM with 4 bit PSK (with wrap around at PCM 0 & 7).· IIRC, broadcast then modulates this to 7 or 8 levels so there's probably some quantization loss.
    So if this fits your receiver requirements, then it may be feasible to use broadcast.
    Composite NTSC sprite driver: http://forums.parallax.com/showthread.php?p=800114
    NTSC color bars (template): http://forums.parallax.com/showthread.php?p=803904
    edited 2009-05-29 15:06
    It seems unlikely that you could transmit anything better than unusable rf noise from the propeller chip
    unless you add external rf hardware parts. If it is just data and not an image you wish to transmit for
    short distances it would be cheap to use an IR LED and an IR phototransistor. You could easily modulate the
    If it is video you wish to transmit I suggest an old surplus modulator from a defunct video game
    or computer that accepts composit input and outputs rf on channel 3 or 4. These were meant to
    connect directly to the antenna input on a tv but if you connect the output to a simple dipole cut
    for the proper frequency it should transmit video at least a few feet with perfect clarity smile.gif
    edited 2009-05-29 16:29
    The Propeller chip alone, with a simple 1/4-wave vertical antenna, does a rather good job of transmitting video on channel 3 over short distances — no external modulator needed. Other channels are not so good, since the PLL generates more jitter at other frequencies. The idea is to pick a frequency such that frqa consists of one or two "one" bits followed by all zeroes.
    I have tried to ameliorate the jitter and the spectral spurs it produces by dithering the phase of the PLL counter, but with only limited success.
    edited 2009-05-29 16:41
    Phil Pilgrim (PhiPi),
    How well does a simple LC tank immediately off of the I/O pin tuned to the appropriate frequency improve spectral spurs?
    Beau Schwabe
    IC Layout Engineer
    edited 2009-05-29 16:58
    Beau,
    Hmm, I haven't tried that, so I don't know. It will probably have to be highly selective, since the worst spurs occur in the same band, on either side of the carrier.
  • hinvhinv Posts: 1,256
    edited 2009-05-31 18:40
    TV broadcast was covered in this thread:
    http://forums.parallax.com/forums/default.aspx?f=25&m=229130
    Checkout the picture of Paul Bakers's protoboard with three resisters and a wire antenna! Quite impressive! I will have to try it.
    Receiving, on the other hand may not be so easy. This is a bit over my head, admittedly.
    ericball: I was able to catch PCM and PSK, but is IIRC? Any reference to the post by Chip?
    PhiPi: Have you tried a 6mhz crystal?
    edited 2009-05-31 18:51
    No, I haven't tried that, but I'm sure it would help on channels 2 and 4.
    edited 2009-05-31 20:39
    Hey Phil. I was searching for the AM radio receiver, then I noticed it was from you.
    http://forums.parallax.com/showthread.php?p=743002
    How difficult would it be to make a transmitter? This receiver seems pretty simple hardware wise.
    Here is some good information on protocol over the air.
    http://forums.parallax.com/showthread.php?p=770046
    Here is a project with some cheap tranceivers from RC cars:
    http://forums.parallax.com/showthread.php?p=789947
    Hopefully these help. This forum has such a wealth of information because of the sharp people on it. It is just a matter of digging in the right places.
    To find the AM radio receiver, I had to do a search for "oklahoma radio" because I just ran into the wav file in my propeller directory. It was a recording of WKY Oklahoma city.
    Maybe there would have been a better way.
    Doug
    Post Edited (hinv) : 5/31/2009 8:44:56 PM GMT
    edited 2009-06-01 13:07
    hinv said...
    If I Recall Correctly
  • LeonLeon Posts: 7,620
    edited 2009-06-01 13:32
    Doug:
    Using a Propeller for transmitting RF might get you into serious trouble. The output wouldn't be clean enough, even if you were authorized to transmit on a particular band.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 6/1/2009 1:43:33 PM GMT
    edited 2009-06-01 15:04
    That's certainly a concern. Even operating under Part 15 of the FCC rules, it would be too easy to cause interference to another service at a frequency you didn't even know you were emitting on.
    Using a spectrum analyzer (expensive, but they can be hired) is the only way to be sure that transmissions are clean.
    Leon
