Broadcast video to be used as a wireless comm. link?
If I understand the Propeller's video hardware correctly, it has the ability to transmit low quality video over the air for a short distance. Is this correct?
If this is indeed correct, can't this be exploited, with a few external components, to transmit data over a short range? Heck, 5 feet would be terrific!
So, is this at all possible? If so, has it been worked on?
On the receiving end there is already a published quadrature demodulator/spectrum analyser.
Looks like frequency modulation might be the way to go.
What would be a good carrier frequency?
What about all those spurious harmonics from the transmitter.
Do we need a couple of transistors for an R.F. amplifier on the receiver?
So if this fits your receiver requirements, then it may be feasible to use broadcast.
Composite NTSC sprite driver: http://forums.parallax.com/showthread.php?p=800114
NTSC color bars (template): http://forums.parallax.com/showthread.php?p=803904
unless you add external rf hardware parts. If it is just data and not an image you wish to transmit for
short distances it would be cheap to use an IR LED and an IR phototransistor. You could easily modulate the
LED using the propeller
If it is video you wish to transmit I suggest an old surplus modulator from a defunct video game
or computer that accepts composit input and outputs rf on channel 3 or 4. These were meant to
connect directly to the antenna input on a tv but if you connect the output to a simple dipole cut
for the proper frequency it should transmit video at least a few feet with perfect clarity
I have tried to ameliorate the jitter and the spectral spurs it produces by dithering the phase of the PLL counter, but with only limited success.
How well does a simple LC tank immediately off of the I/O pin tuned to the appropriate frequency improve spectral spurs?
Beau Schwabe
IC Layout Engineer
Hmm, I haven't tried that, so I don't know. It will probably have to be highly selective, since the worst spurs occur in the same band, on either side of the carrier.
http://forums.parallax.com/forums/default.aspx?f=25&m=229130
Checkout the picture of Paul Bakers's protoboard with three resisters and a wire antenna! Quite impressive! I will have to try it.
Receiving, on the other hand may not be so easy. This is a bit over my head, admittedly.
ericball: I was able to catch PCM and PSK, but is IIRC? Any reference to the post by Chip?
PhiPi: Have you tried a 6mhz crystal?
http://forums.parallax.com/showthread.php?p=743002
How difficult would it be to make a transmitter? This receiver seems pretty simple hardware wise.
Here is some good information on protocol over the air.
http://forums.parallax.com/showthread.php?p=770046
Here is a project with some cheap tranceivers from RC cars:
http://forums.parallax.com/showthread.php?p=789947
Hopefully these help. This forum has such a wealth of information because of the sharp people on it. It is just a matter of digging in the right places.
To find the AM radio receiver, I had to do a search for "oklahoma radio" because I just ran into the wav file in my propeller directory. It was a recording of WKY Oklahoma city.
Maybe there would have been a better way.
Doug
Post Edited (hinv) : 5/31/2009 8:44:56 PM GMT
Using a Propeller for transmitting RF might get you into serious trouble. The output wouldn't be clean enough, even if you were authorized to transmit on a particular band.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 6/1/2009 1:43:33 PM GMT
Leon
