I had a mishap with a BS2SX OEM board Kit either a bad regulator or a bad cap a
When I use the RUN Identify icon it would not see the Basic Stamp SX Board
I though that a little weird that amp meter was showing 70 milliamp
When I do a Basic Stamp Board kit it only 10· millamps just the board only
So UN hook it real fast and check the VDD pin and found 8 volts where· I···should have 5 volts
That was real·bad·but I had two more kit so put a 7805 regulator and now I··have 5 volts
and ran··· RUN· .......···Identify···did not see it so I·put the other Basic Stamp SX chip and The EROM Chip
and· RUN......... Identify still did not see the board
· So I called Parallax Tech Support and talked to Joshua
They told me to try this and still did now work then try this
So the Tech ask me if had the newest VER of the editor
and I told I did·....................
Well I did on the Desk Top··Computer that was not the one·I·used to down load the Pbasic Code
It·was the Lap Top Computer that I was using to down load the code with
One I down Load The Newest Ver To my Laptop and another new board I was rocking and Rollen·
I want to Thank·Joshua· For all the help that he gave me ..........>>>>>>>
With his Help on the Phone I was able to see the Basic Stamp SX
Joshua also when the extra mile and put a Basic Stamp SX board togeher him self to see if there where any problem on there end
I love Tech Support At Parallax they rock
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/28/2009 3:37:45 AM GMT
··Thanks for any·
Sam
