Voltage Regulator
I am building my own dual motor controller for 12volt motors ...yeah I know why not just buy parallax's... simple I like to see if I can do it myself. Anyhow during my design I though... why put 12v and 5v to the board when I can just build in a 5v regulator on the main board and let the 12v motor power also power all the logic.. I chose the 7805 in the 8 pin soic package.. I thought that 100ma would be plenty but it's getting really hot. So I need a small design revision.
Can someone recommend a 5v regulator in a small package that can give me more current capacity. I've looked around and quite frankly the are tons of voltage regulators.
Thanks in advance,
Eric
Thanks in advance,
Eric
It is usually not a good idea to run motors and electronics from the same supply. The motors will generate alot of noise on the power lines.
As for the heat, try putting a resistor before the regulator so the regulator doesn't have to disapate all the heat. A 39 ohm 1/2 watt resistor should do it.
That way instead of the regulator disapating 0.7W ((12-5)=7 volts * 0.1 Amp) the resistor is disapating 0.39Watts and the regulator is disapating (0.70-0.39) or 0.31 Watts.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
The motor controller seems to be working well right now during preliminary tests.. No glitches yet. Except for the hot regulator. Many tests to go.
Thanks again for you help.
Eric
Would bringing down the voltage in steps using a 7809 prior to the 7805 or using a Switching regulator be viable options?
I can tell you what I think about how well they work if you would like me to Please let me know
http://www.futurlec.com/Mini_Power.shtml
This·is what the board look like
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/23/2009 12:34:24 AM GMT
I did some testing on this board
Voltage was set @ 12 Volts
5.00 volts @ no load
·4.97 volts·@·600 mill-amps
This load was left on for about 2 minutes and the regulator did not even get warm the rectifier did get a little warm This was DC voltage
The board is rated @ 1 amp with the input voltage no more than 12 volts Range is 7· to· 12 volt
So from this test it·tell me that if you· use a Basic Stamp or SX chip and a LCD Display it should work very good for that
Here is a another Regulator Board
http://store.nutsvolts.com/product.php?productid=16725&cat=379&page=1
The voltage can be as high as 30 volts if·I remember right Please look at the Data Sheet
This board is rated at 3 amp
This board· has a ADJ regulator you can use a 5 volt version and leave out the pot
The test·I did on this board was a little better 4.99 volts @ 600 mill amps
I have use· this board before and work very well·I used in the Elapsed·Equipment Timer Project had post a while back on the Forum
I power the Basic Stamp and DS1302 a LCD Display with the back light on most of the time ·and the regulator dose not get warm at all I did put a heat sink on it just in case
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/26/2009 12:52:02 AM GMT
Thanks for that... IT's appreciated... Ya know I played around with Switching Regulators.. and made myself a 3.3v and 5v dual power supply.. That was fun.. Here is the link
http://forums.parallax.com/showthread.php?p=691979
Actually... I noticed some comments from you on there. [noparse]:)[/noparse]
How did those boards work out for you
I would to have 5 and a 12 volts on one board
I could use this in some of the projects have made before
Did you make any more of them
If you do Please Let Me Know
I forgot about that Post until I look at it again
··Thanks for any·
Sam
I forgot about that post also until you posted the photo of that switching regulator.
Thank You··
··Thanks for any·
Sam
Just looking for the board only
I will pay you for the boards when you order more for your self· I am looking for three of them
··Thanks for any·
Sam
