Voltage Regulator — Parallax Forums
Voltage Regulator
SailerManSailerMan Posts: 337
edited 2009-05-28 22:46 in General Discussion
I am building my own dual motor controller for 12volt motors ...yeah I know why not just buy parallax's... simple I like to see if I can do it myself. Anyhow during my design I though... why put 12v and 5v to the board when I can just build in a 5v regulator on the main board and let the 12v motor power also power all the logic.. I chose the 7805 in the 8 pin soic package.. I thought that 100ma would be plenty but it's getting really hot. So I need a small design revision.
Can someone recommend a 5v regulator in a small package that can give me more current capacity. I've looked around and quite frankly the are tons of voltage regulators.
Thanks in advance,
Eric
  • BeanBean Posts: 8,129
    edited 2009-05-22 12:07
    Eric,
    It is usually not a good idea to run motors and electronics from the same supply. The motors will generate alot of noise on the power lines.
    As for the heat, try putting a resistor before the regulator so the regulator doesn't have to disapate all the heat. A 39 ohm 1/2 watt resistor should do it.
    That way instead of the regulator disapating 0.7W ((12-5)=7 volts * 0.1 Amp) the resistor is disapating 0.39Watts and the regulator is disapating (0.70-0.39) or 0.31 Watts.
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
  • SailerManSailerMan Posts: 337
    edited 2009-05-22 12:29
    Thanks bean... I would have never thought to do that..This motor controller thingy that I'm playing with uses an SX48 to control two vnh2sp30 motor chips.. and there are 4 smt led. each with 270 ohm resistor. I'm going to have to look at the data sheets but I think I'm under budget on current draw. but I'm thinking that maybe a better regulator might be a good choice.
    The motor controller seems to be working well right now during preliminary tests.. No glitches yet. Except for the hot regulator. Many tests to go.
    Thanks again for you help.
    Eric
    edited 2009-05-22 15:02
    At minimum you should put a diode and capacitor between the 12V and the resistor/regulator so that the high start current of a motor does not cause the input voltage to the regulator to sag.
  • Brad_HBrad_H Posts: 35
    edited 2009-05-22 18:27
    Hello Eric,
    Would bringing down the voltage in steps using a 7809 prior to the 7805 or using a Switching regulator be viable options?
    edited 2009-05-22 19:37
    All good Ideas.. I was hoping for a suggestion on one regulator.. I'll keep up the search.. Maybe just a D2Pak 7805. Oh here is a Picture of the controller. I'm kinda proud of it mainly because it works. [noparse]:)[/noparse] Goals to have motor speed feedback and current monitoring.
    640 x 480 - 93K
    640 x 480 - 88K
  • SRLMSRLM Posts: 5,045
    edited 2009-05-22 20:42
    mouser has some linear regulators that are rated for up to 3 amps.
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-05-22 23:14
    For nearly all my designs, I use TI's uA78mXX regulators. The XX could be 05(5V), 33(3V), 12(12V). They come in a D2PAK and can handle 500mA. The part is in their sample program, so order a few(up to 10 I think), and try them out in your design.
    edited 2009-05-23 00:26
    Take a look at this I just bought 6 of them they are very nice board I have not use they yet
    I can tell you what I think about how well they work if you would like me to Please let me know
    http://www.futurlec.com/Mini_Power.shtml
    This·is what the board look like
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 5/23/2009 12:34:24 AM GMT
    edited 2009-05-26 00:16
    UpDate
    I did some testing on this board
    Voltage was set @ 12 Volts
    5.00 volts @ no load
    ·4.97 volts·@·600 mill-amps
    This load was left on for about 2 minutes and the regulator did not even get warm the rectifier did get a little warm This was DC voltage
    The board is rated @ 1 amp with the input voltage no more than 12 volts Range is 7· to· 12 volt
    So from this test it·tell me that if you· use a Basic Stamp or SX chip and a LCD Display it should work very good for that
    Here is a another Regulator Board
    http://store.nutsvolts.com/product.php?productid=16725&cat=379&page=1
    The voltage can be as high as 30 volts if·I remember right Please look at the Data Sheet
    This board is rated at 3 amp
    This board· has a ADJ regulator you can use a 5 volt version and leave out the pot
    The test·I did on this board was a little better 4.99 volts @ 600 mill amps
    I have use· this board before and work very well·I used in the Elapsed·Equipment Timer Project had post a while back on the Forum
    I power the Basic Stamp and DS1302 a LCD Display with the back light on most of the time ·and the regulator dose not get warm at all I did put a heat sink on it just in case
    Sam
    Post Edited (sam_sam_sam) : 5/26/2009 12:52:02 AM GMT
    edited 2009-05-26 00:49
    Sam_Sam_sam,
    Thanks for that... IT's appreciated... Ya know I played around with Switching Regulators.. and made myself a 3.3v and 5v dual power supply.. That was fun.. Here is the link
    http://forums.parallax.com/showthread.php?p=691979
    Actually... I noticed some comments from you on there. [noparse]:)[/noparse]
    edited 2009-05-26 00:59
    SailerMan
    How did those boards work out for you
    I would to have 5 and a 12 volts on one board
    I could use this in some of the projects have made before
    Did you make any more of them
    If you do Please Let Me Know
    I forgot about that Post until I look at it again
    Sam
    edited 2009-05-26 01:18
    I never did make anymore.. but I still use the original one every day. I was actually going to pick that project up again. I know that I can buy things but it fun to make them myself if I can. I just have to finish my motor board.
    I forgot about that post also until you posted the photo of that switching regulator.
    edited 2009-05-28 01:37
    Please let me know if you make any more boards
    Sam
    edited 2009-05-28 12:25
    Do you just want the board or do you want it populated?
    Sailer Man
    Just looking for the board only
    I will pay you for the boards when you order more for your self· I am looking for three of them
    Sam
