Looking for joystick links...
No...this isn't a request for porn....I am looking for a good quality, PC mount joystick with more resolution then 5K ohms.· Would like a push down feature of the joystick for a switch.· I am presently breadboarding with a 5K ohm, thumb operated unit, but I find that it is to coarse for operation with the HB25.· Trying to avoid jack rabbit starts.
Once again...Thank to all for reading and·any links...DenO·
· You can always use the Stamp to "ramp up" the signal to the HB-25 thereby avoiding wear and tear of quick starts.
· I did this with and HB25 on a kid's electric car and it worked like a charm even though the joystick was an 8-position switch-only model.
· http://siskconsult.com/elcar.wmv
· Cheers
Tom Sisk
http://www.siskconsult.com
www.allelectronics.com/index.php?page=search&search_query=joy+stick&x=20&y=4
Mike2545
This message sent to you on 100% recycled electrons.
DenO
Chris Savage
Parallax Engineering
Thank you Chris for your reply.· Can you please tell me what the ohmic value of the pots are on this/your joystick?· Is there any data available?
Deno
Yes, but are you working on the joystick smiley as well?
Mike2545
Chris Savage
