Need to send serial data over Internet. ( Please Help)
Hi,
I need to send serial data from a Basic Stamp
to a computer using Internet.
My idea is to receive the data from the Basic Stamp with a computer,
but the computer will be in an other city , for this reason I need Internet
communication.
I know that I need a fixed IP.
Do you know how can I send the data over Internet.
Thanks, Joe
communication.
Thanks, Joe
There are some companies that sell Telnet interfaces that look like a standard serial port to the the Stamp. You can find adverts in magazines like Nuts and Volts and Circuit Cellar.
Thanks . I don't know if the PINK (Parallax Internet Netburner Kit)
could send the data over Internet.
Do you know ?
Thanks.
PS: I saw an other item from Parallax called HYDRA EtherX Card.
But it seems that it is for other kind of application ( do you know? )
SitePlayer (www.siteplayer.com) is one manufacturer of serial to Telnet adapters that allow you to set up a serial connection via the Internet. That may be more what you're looking for.
I attached a quick and dirty version of what you want.
If you dont have Visual Studio 2008 you can download it from Microsoft. Get Visual Basic Express.
Open the attached zip and open the .sln (solution) file.
It will show you the Form window. Click on the SerialPort1 on the bottom of the screen, and it will show properties window on the right for it.
Scroll down and find COM3, change this to yours (unless thats what you have.)
Now press F5 or click run on the menu bar. Click connect, if it gives you error, then you have the wrong COM port selected.
I attached also the BS2 file. You may need to modify the number in the If-Then Statement. The commented out code is for a PING))) sensor but can easily be modified to send whatever data you may need
Post Edited (GeorgeL) : 5/14/2009 12:17:09 AM GMT
Did You mean ?
Generic Bluetooth Receiver.rar
Cool link,Thanks
______$WMc%______
The Truth is out there············································ BoogerWoods, FL. USA
