HS1011 Humidity Sensor — Parallax Forums
Matthew BurmeisterMatthew Burmeister Posts: 49
edited 2009-05-08 04:19 in Propeller 1
i have been working on the HS1011 for a couple of hours, but i haven't have any success. i get results from 9 to 256. (i used a byte instead of a word to limit it from going above 256). Maybe it's my code or wiring.
con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
RHconstant = 12169
var
long returnlong
long humsen
byte humidity
pub main
tv.start(12)
repeat
  clk.MS(1000)
  tv.out($00)
  tv.str(string("Propeller Weather System"))
  tv.out($0d)
  tv.str(string("Humidity: "))
  rc.rctime(16,1,@humsen)
  humidity := (humsen - RHconstant) / 24
  TV.Str(Num.ToStr(humidity, Num#DEC))
If it is my code, any fixes or does anyone have a driver for it?
If it's wiring, any suggestions?
  • CassLanCassLan Posts: 586
    edited 2009-05-08 03:58
    Does it change capacitance based on humidity? Because you need a resistance and a capacitace for an rc time measurement.
    Also it seems like the black wire, both leads of the resistor and one end of the sensor are all touching, I'm sure this is not what you want.
    Rick
    Post Edited (CassLan) : 5/8/2009 4:09:25 AM GMT
  • Matthew BurmeisterMatthew Burmeister Posts: 49
    edited 2009-05-08 04:06
    I'm not sure if it does change capacitance when humidity changes. It fluctuates to much to tell.
    edited 2009-05-08 04:09
    not sure if you caught my edit above Matthew, try moving one end of the resistor and the black wire over one row in the breadboard.
    Rick
    Same Result. I think it's a programming error?
