HS1011 Humidity Sensor
i have been working on the HS1011 for a couple of hours, but i haven't have any success. i get results from 9 to 256. (i used a byte instead of a word to limit it from going above 256). Maybe it's my code or wiring.
If it is my code, any fixes or does anyone have a driver for it?
If it's wiring, any suggestions?
con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
RHconstant = 12169
var
long returnlong
long humsen
byte humidity
pub main
tv.start(12)
repeat
clk.MS(1000)
tv.out($00)
tv.str(string("Propeller Weather System"))
tv.out($0d)
tv.str(string("Humidity: "))
rc.rctime(16,1,@humsen)
humidity := (humsen - RHconstant) / 24
TV.Str(Num.ToStr(humidity, Num#DEC))
Also it seems like the black wire, both leads of the resistor and one end of the sensor are all touching, I'm sure this is not what you want.
Rick
Post Edited (CassLan) : 5/8/2009 4:09:25 AM GMT
Rick
