Tcs230
                    I am using the TCS230 to ic color  but instead of debugging out I want it to trigger ports high or low on the prototyping daughter board. its been a really long time since I have played with a stamp. I have found the sample code. I don't know how to have the stamp compare what it is "seeing" to what would be in a table got a specif color range and then to run a subroutine based off of that.
the issue is that when the code is ran it says that all levels are at 100 and thus nothing matches
in the final sub routine I am attempting to have it output to a set transistors
' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- TcsLed PIN 12 ' LEDs enable - active low TcsOut PIN 11 ' freq from TCS230 S2 PIN 9 ' color filter control S3 PIN 8 ' color filter control Rout0 PIN 5 'port d Rout1 PIN 1 'port e Rout2 PIN 0 'port f Rout3 PIN 2 'port h Rout4 PIN 3 'port g ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Red CON 0 ' TCS230 filter selection Green CON 1 Blue CON 2 Clear CON 3 ScanTime CON 10 ' scan time in millisecs ScaleMax CON 100 ' max for scaled values IsOn CON 0 ' LED control is active low IsOff CON 1 NumColors CON 7 ' seven M&M colors ColorThresh CON 10 ' allowable variance TermChar CON 0 ' terminater for strings StrLen CON 12 ' max length of names ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- filter VAR Nib ' filter selection rawColor VAR Word ' raw return from TCS230 calRed VAR Word ' red calibration calGrn VAR Word ' green calibration calBlu VAR Word ' blue calibration redVal VAR Byte ' red value grnVal VAR Byte ' green value bluVal VAR Byte ' blue value rgb VAR redVal ' colors array inKey VAR Byte ' input from user colIdx VAR Nib ' color index rgbIdx VAR Nib ' rgb index testVal VAR Byte ' test value eePntr VAR Word ' data table pointer char VAR inKey ' char to print ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- ' RGB data Colors DATA 038, 007, 005 ' red DATA 075, 022, 008 ' orange DATA 086, 060, 011 ' yellow DATA 019, 044, 020 ' green DATA 021, 017, 031 ' violet ' Color Names CN0 DATA "Red", 0 CN1 DATA "Orange", 0 CN2 DATA "Yellow", 0 CN3 DATA "Green", 0 CN4 DATA "Violet", 0 ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Setup: TcsLed = IsOff ' start off OUTPUT TcsLed ' allow direct control GOSUB Calibrate_White ' white balance sensor GOSUB Calibrate_Colors ' calibrate color table ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO GOSUB Read_RGB ' scan color DEBUG "RGB = ", ' display components DEC3 redVal, ", ", DEC3 grnVal, ", ", DEC3 bluVal, " " GOSUB Match_Color ' compare scan to table IF (colIdx < NumColors) THEN ' match was found GOSUB Print_Color GOSUB Show_Color DEBUG CR ELSE DEBUG "No match", CR ENDIF PAUSE 5000 ' delay between scans LOOP END ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- ' Calibrates "white" to ambient conditions Calibrate_White: DEBUG CLS, "TCS230 White Balance" DEBUG CR, CR, "Insert white Press key to scan." DEBUGIN inKey GOSUB White_Balance DEBUG CR, CR, "White balance complete." PAUSE 1000 DEBUG CLS RETURN '======================White balance============================================== ' Reads "white" and calculates calibration values White_Balance: filter = Red GOSUB Read_Color ' read raw red calRed = ScaleMax * 256 / rawColor ' calculate red cal filter = Green GOSUB Read_Color ' read raw green calGrn = ScaleMax * 256 / rawColor ' calculate green scale filter = Blue GOSUB Read_Color ' read raw blue calBlu = ScaleMax * 256 / rawColor ' calculate blue scale RETURN '========== calibrate Colors====================================================== ' Calibrates color table to ambient conditions Calibrate_Colors: FOR colIdx = 0 TO (NumColors - 1) ' loop through all colors DEBUG CLS, "TCS230 Color Calibration: " GOSUB Print_Color DEBUG CR, CR, "Insert Color Press key to scan." TcsLed = IsOn ' light up scan area DEBUGIN inKey GOSUB Read_RGB ' scan sample item eePntr = Colors + (3 * colIdx) ' point to table entry WRITE eePntr, redVal, grnVal, bluVal ' save new data NEXT DEBUG CLS RETURN '======Read Color========================================================= ' Reads selected color from TCS230 ' -- takes "filter" as input ' -- returns "rawColor" as output (unscaled color value) Read_Color: SELECT filter CASE Red LOW S2 LOW S3 CASE Green HIGH S2 HIGH S3 CASE Blue LOW S2 HIGH S3 CASE ELSE ' clear -- no filter HIGH S2 LOW S3 ENDSELECT TcsLed = IsOn ' light sample COUNT TcsOut, ScanTime, rawColor ' return unscaled value TcsLed = IsOff RETURN '====Read RGB=============================================================== ' Reads and scales RGB colors Read_RGB: filter = Red GOSUB Read_Color redVal = rawColor */ calRed MAX ScaleMax filter = Green GOSUB Read_Color grnVal = rawColor */ calGrn MAX ScaleMax filter = Blue GOSUB Read_Color bluVal = rawColor */ calBlu MAX ScaleMax RETURN '====Match Color============================================================ ' Compares current color scan with known values in ' table. If match is found, the value of "colIdx" ' will be less than "NumColors" Match_Color: colIdx = 0 DO WHILE (colIdx < NumColors) ' check known colors rgbIdx = 0 DO WHILE (rgbIdx < 3) ' compare rgb components eePntr = Colors + (colIdx * 3) + rgbIdx ' point to color table READ eePntr, testVal ' read known r, g or b testVal = ABS(testVal - rgb(rgbIdx)) ' calculate variance IF (testVal > ColorThresh) THEN EXIT ' if out-of-range, next rgbIdx = rgbIdx + 1 ' test next component LOOP IF (rgbIdx = 3) THEN EXIT ' match found colIdx = colIdx + 1 ' try next color LOOP RETURN '====Print Color============================================================ ' Print color name ' -- takes "colIdx" as input ' -- allow this to fall through to Print_String Print_Color: LOOKUP colIdx, [noparse][[/noparse]CN0, CN1, CN2, CN3, CN4], eePntr '=======Print_String======================================================== ' Print a string stored in DATA table ' -- point to first character with "eePntr" Print_String: DO READ eePntr, char ' reach character IF (char = TermChar) THEN EXIT ' end of string? DEBUG char ' no -- print char eePntr = eePntr + 1 ' point to next LOOP RETURN '====Show_Color============================================================= ' ' Show_Color displays the name of the found color on the LCD screen. ' Show_Color: ' print color name on screen SELECT eePntr CASE 0 GOSUB No_Color CASE 1 GOSUB Red_Found CASE 2 GOSUB Orange_Found CASE 3 GOSUB Yellow_Found CASE 4 GOSUB Green_Found CASE 5 GOSUB Purple_Found ENDSELECT DEBUG CR RETURN '-------[noparse][[/noparse]color subroutines]------------------------ 'each sub routine is setup in a way that allows the "serial out" to the robot No_Color: LOW Rout0 LOW Rout1 LOW Rout2 LOW Rout3 LOW Rout4 DEBUG "no color found" Red_Found: HIGH Rout0 LOW Rout1 LOW Rout2 LOW Rout3 LOW Rout4 DEBUG "Found Red" Orange_Found: LOW Rout0 HIGH Rout1 LOW Rout2 LOW Rout3 LOW Rout4 DEBUG "Found Orange" Yellow_Found: LOW Rout0 LOW Rout1 HIGH Rout2 LOW Rout3 LOW Rout4 DEBUG "Found Yellow" Green_Found: LOW Rout0 LOW Rout1 LOW Rout2 HIGH Rout3 LOW Rout4 DEBUG "Found Green" Purple_Found: LOW Rout0 LOW Rout1 LOW Rout2 LOW Rout3 HIGH Rout4 DEBUG "Found Purple"
