Tcs230
I am using the TCS230 to ic color but instead of debugging out I want it to trigger ports high or low on the prototyping daughter board. its been a really long time since I have played with a stamp. I have found the sample code. I don't know how to have the stamp compare what it is "seeing" to what would be in a table got a specif color range and then to run a subroutine based off of that.
the issue is that when the code is ran it says that all levels are at 100 and thus nothing matches
in the final sub routine I am attempting to have it output to a set transistors
