Video overlay with prop for the AutoProp8 autopilot
I know its been done. I have an LM1881 sync separator chip. I want to overlay the TV video I am generating now on top of some camera video. How do you sync the two? How to 'paint' the prop generated video ? This is for my autopilot project
Post Edited (Ole Man Earl) : 5/7/2009 1:58:40 AM GMT
His website did say that he's no longer selling products through his website as of April 1st according to a snapshot by Google.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Aka: CosmicBob
EL1883 still seems to be a current product from Intersil. LM1881 still works, but for future projects I'll opt for the EL1883.
Jim
Anyone else need one ?
Here is a crappy screen shot of the overlay...
Post Edited (Ole Man Earl) : 5/5/2009 1:07:39 AM GMT
www.igniteautomation.com/hc-osd.html
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
Any other ideas ?
BTW, this takes up about the same room as tv.text that I don't need now AND it only takes up 2 PINS.
Another pic here
You can see even in a bright area of the screen the data comes thru...
Post Edited (Ole Man Earl) : 5/5/2009 2:09:09 AM GMT
The LM1881 chips composite output pin 1 goes to pin 0 of the prop. pin 1 of the prop go to a video out connector. The camera input connector has a 47 ohm resister to the output jack and a connection to pin 2 of the LM1881. Sounds complicated, but this is simpler than using tv.text object !
here is another shot while I look for a better camera !
Post Edited (Ole Man Earl) : 5/5/2009 4:20:18 AM GMT
Post Edited (Ole Man Earl) : 5/5/2009 6:50:48 PM GMT
This project has grown far bigger than I had planed !
Post Edited (Ole Man Earl) : 5/5/2009 7:37:32 PM GMT
I think this is brilliant. Just what I need to put alerts and alarms up on the TV when everyone is glued to it.
Anyone know how it would be possible to do this using SCART on PAL TV. It would have to sit between my telly and the digibox.
either way it'd be possible, you'd just have to approach it in a different way if it's RGB but still possible [noparse]:D[/noparse]
To:
In less than 24 hrs, with pictures, code and a schematic!
Definitely something that I want to duplicate.
Rich H
I'm retired and have a lab in my house on the ranch here in NM. Only time I get nervous is when the horses come snooping around !
PS. Ya work harder and longer when your retired....
I'm looking forward to it. My father bought his first computer and started to learn to program it when he retired in the early 1980s.
Trouble is it doesn't look like I'll have the ranch or the horse by then[noparse]:([/noparse].
I picked up a few of those chips a year ago..
You're starting to motivate me to locate them.. [noparse]:)[/noparse] Awesome work!
OBC
New to the Propeller?
failing that, if you test the pins on the scart lead http://en.wikipedia.org/wiki/SCART for data coming in through the Composite output or RGB red/green/blue [noparse];)[/noparse]
or if you don't have something to test the pins, you could open the scart connector cable at the tv end and see what pins are connected ( unless you bought it seperately and not with the digibox )
The monitor has vga input, composite input, hdmi input, RGB input , S video input AND digital tv tuner built in. 22" digi TV ! on sale for $200. Couldn't pass it up. I always was one kind of input or another short. This fixes that!
Here is some pics of TV AND a pic of the prop proto board and sensors.
Latest S/W here.
Post Edited (Ole Man Earl) : 5/6/2009 12:26:30 AM GMT
BTW If I can do it, so can you...I am 63 and retired.
That's for sure!
Are you getting reliable compass readings with it right on the board like that?
Rich H
