conditional compiler directives — Parallax Forums
bob kruggelbob kruggel Posts: 50
edited 2009-05-04 14:39 in General Discussion
I'm new to SXB. I keep reading about, and seeing "examples" of conditional compiler directives. However I don't find reference to them in any documentation about SXB or the IDE. It's obvious to me that I don't understand conditional compiler directives at all, even though I thought I did. Can· someone help me to end the confusion?
  • RS_JimRS_Jim Posts: 1,775
    edited 2009-05-02 11:21
    BobK
    Read the what's new in the above stickey thread about SXB 2.0 Beta. You will find a lot of information about conditional compiler directives. If you type ifdef into Help there is some more info on conitional directives. I hope this helps.
    RS_Jim
  • ZootZoot Posts: 2,227
    e.g.
    '{$DEFINE UsePortC}
    '{$IFDEF UsePortC}
    serialOut PIN RC.0
    '{$ELSE}
    serialOut PIN RB.0
    '{$ENDIF}
    If you remove the DEFINE line, then the program will compile with RB.0 as the serial out pin, otherwise RC.0 will be the pin. Just an example, of course.
