conditional compiler directives
I'm new to SXB. I keep reading about, and seeing "examples" of conditional compiler directives. However I don't find reference to them in any documentation about SXB or the IDE. It's obvious to me that I don't understand conditional compiler directives at all, even though I thought I did. Can· someone help me to end the confusion?
BobK··
BobK··
Read the what's new in the above stickey thread about SXB 2.0 Beta. You will find a lot of information about conditional compiler directives. If you type ifdef into Help there is some more info on conitional directives. I hope this helps.
RS_Jim
'{$DEFINE UsePortC} '{$IFDEF UsePortC} serialOut PIN RC.0 '{$ELSE} serialOut PIN RB.0 '{$ENDIF}If you remove the DEFINE line, then the program will compile with RB.0 as the serial out pin, otherwise RC.0 will be the pin. Just an example, of course.
