3.3 volt to 5 volt IC — Parallax Forums
Zap-oZap-o Posts: 452
edited 2009-04-30 03:40 in General Discussion
I have been looking all over for a 3.3 volt to 5 volt buffer to put between the propeller and another device. I know that a resistor will work, but has some company made an IC that can buffer between the 2 voltages?
I searched Google but think I am wording it incorrectly. Voltage buffer? 3.3 - 5 V buffer ? Any help will be appreciated.
    edited 2009-04-29 22:13
    There is a long thread on interfacing between 3.3V logic and 5V logic with lots of suggestions and links to information.
    It's one of the "sticky" threads in the Propeller Forum list called "Propeller: Getting Started and Key Thread Index" under the topic Technical Considerations.
  • Zap-oZap-o Posts: 452
    Thanks Mr.Green.
  • TubularTubular Posts: 4,768
    Texas Instruments (TI) have some interesting bidirectional IC's specifically for this. I haven't used them. There may be other brands
    Try searching for these terms
    ti level translation
    ti level translator
    level shifter
    TXB0104
    TXS0104E
    good luck
    tubular
