BASIC Stamp & StampPlot Pro V3.8
Due to the fact that StampPlot Lite does not exist and replaced by StampPlot Pro V3.8 I need to know how to use PlotPhotoresistor.bs2 (What's a Microcontroller? page 196) with this new soft, I can't find the same windows. Thanks in advance.
http://www.parallax.com/tabid/441/Default.aspx
Dave
Dave Andreae
Parallax Tech Support
Post Edited (Dave Andreae (Parallax)) : 4/20/2009 6:16:52 PM GMT
There is also some macro's for Stamp Plot Pro available that will help you follow the text as well. Here is the download for both Lite or if you want to keep using Pro with the macros.
Stamp Plot Lite:
http://www.parallax.com/Portals/0/Downloads/sw/spl.zip
Stamp Plot Pro Macros:
http://www.parallax.com/Portals/0/Downloads/src/prod/PC-Macros-v1.0.zip
Respectfully,
Joshua Donelson
www.parallax.com
Best regards.
MichelB
If you wanted to use the Stamp Plot Lite instead, it still is available for download. The zip file for install is listed above; perhaps that will be a little easier than sorting through the options in the Pro version. Please let me know if you are having issues installing the Lite version.
Respectfully,
Joshua Donelson
www.parallax.com
Best regards. MichelB
I'm not sure what could be causing the issue; I to have XP pro and that is the file I have used to install as well. Did you unzip the file to your hard drive and then run the install?
Respectfully,
Joshua Donelson
www.parallax.com
I'm very sorry but I can't install Spl.zip (1.55 MB) downloaded from the above link. It seems that setup.exe (Setup Bootstrap for Visual Basic Toolkit) is corrupted (!) or one file misses. This morning I tried on a PC of my friend without success. You may try your self to install. If needed I can send you this file.
Best regards.
MichelB
That is strange, I just installed the Lite version without any errors. Can you take a screen shot of the errors that you encounter? I can't seem to duplicate it.
Respectfully,
Joshua Donelson
www.parallax.com
please find herewith attached a doc file (Word) with screen shots, no files were in use during installation. For the 3rd screen shot I tried one time "OK" and a second time "Exit Setup", result is the same.
Best regards.
MichelB
Tia'Shar Manetheren
I removed the existing application from my machine and installed the version that is in the spl.zip file you provided; I didn't encounter any errors during the install process. I tried a search online for the file that it seems to be having an issue editing; but couldn't find anything conclusive.
What Anti-Virus software do you have protecting the network?
Respectfully,
Joshua Donelson
www.parallax.com
Post Edited (MichelB) : 4/30/2009 3:56:45 PM GMT
It was no disturbance at all; that is what we are here for. Glad it is working now, just let me know if anything else comes up.
Respectfully,
Joshua Donelson
www.parallax.com
